Tre57 | This week's project | ||
I am in the middle of installing a new audio system and I ran across some wires and plugs that are not connected to anything or have been taped off. One is near the right-rear defroster lead and the other is near the pwr seat controls. Can anyone identify these?
The audio system is almost done. I need to locate and install some quick-disconnects for the front speakers and route the front wires. I will post the details in audio when it's finished (at least this phase). |
Posted on: 2010/9/17 17:39
93 AT Coupe |
bogus | Re: This week's project | ||
the wires in pic one are for accessories.
It's live all the time. I guess it was designed for CB radios, early cell phone conections... things like that. I use mine for a set of parade strobes. Otherwise, great project! Look'n GOOD!!!!! |
Posted on: 2010/9/17 18:00
1Fast04Vert | Re: This week's project | ||
One is hot all the time, one is keyed hot, and the third one is a ground. They are factory wires for accessories the owner might want to wire in later. |
Posted on: 2010/9/17 18:20
Tre57 | Re: This week's project | ||
Excellent, thanks guys! I was planning on adding seat heaters when I redo the seats so that will be handy.
Posted on: 2010/9/17 18:36
93 AT Coupe |
I would NOT use that feed for seat heaters... if you do, be sure to add a relay and get power from somewhere else.
Posted on: 2010/9/17 19:05
Exactly Andy. I would use those wires for the switches only. The main power will might come from the existing side bolster or lubmar motor power leads. When I redo the seats, I plan on converting them to the standard type. My side bolsters and lumbar inflatables don't work and I like the look of the standard seats better. (plus I don't think the seat heaters would work with the sport seat's speed bumbs.)
Posted on: 2010/9/17 19:34
93 AT Coupe |
