252 user(s) are online (209 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
Mekanic Brake Pressure Light
Tampa Bay Florida
827 Posts
Was driving the vette and the brake pressure light came on, still stops great.
Couple days later now, light is still on, pedal feels stiffer than it used to.
Any info?
When I get home from work I thought about putting my autotap on it, but I have no idea if that will report anything.
~Rich
Posted on: 2010/10/8 19:22
~Rich
Polo LT4
bogus Re: Brake Pressure Light
I assume the fluid level is ok...
Posted on: 2010/10/8 19:45
tjpreul Re: Brake Pressure Light
Mine comes on when the door is open. The dash was changed at one point. I know this isn't helpful, just wanted to type something.
Posted on: 2010/10/8 20:11
Mekanic Re: Brake Pressure Light
Tampa Bay Florida
827 Posts
yeah the fluid level is good.
lol tj
Posted on: 2010/10/8 22:57
~Rich
Polo LT4
BillH Re: Brake Pressure Light
FSM says, pull the one wire to the hand brake, then connector #1 on the ignition switch, then pull the connector on the M/C switch.
Posted on: 2010/10/8 23:00
Tampa Bay Florida
827 Posts
where would connector 1 on the ignition switch be?
I fear taking my column apart is in my future lol
Posted on: 2010/10/9 0:07
~Rich
Polo LT4
na, there is a harness connector down on the column. Big greyish thing.
Posted on: 2010/10/9 0:23
Yea, what Andy said, the damn FSM saya to pull conn 1 but not conn2 then when you look at the bottom of the column pic, the f__kin thing's not labeled 1 & 2.
BTW, pull the parking brake wire, light still on? Light off - it's the switch or switch adjustment. Then the ign, if the light's off, it's probably the ign switch. Light stays on-Pull the wire in the m/c, Light on - probably a short. Light off - m/c problem (hydraulic) or bad m/c switch.
Posted on: 2010/10/9 12:55
Tampa Bay Florida
827 Posts
vacuum cause it?
I have a vacuum line off from my cruise control servo that I can't trace.
It's not the one going to the T right near the fender, tis the other one that runs back passed the master cylinder, anyone know where the hell it goes?
Posted on: 2010/10/10 18:09
~Rich
Polo LT4
Mekanic wrote:
vacuum cause it?
Nope.
Posted on: 2010/10/10 18:46
Tampa Bay Florida
827 Posts
BillH wrote:
Mekanic wrote:
vacuum cause it?
Nope.
Damn, nothing can be easy.
Now unrelated, but can anyone tell me where the hell that line goes? I miss my cruise control lol
Posted on: 2010/10/10 22:29
~Rich
Polo LT4
