189 user(s) are online (143 user(s) are browsing Forums)
Dale1990 Clutch slave bolt holes stripped
Conway, AR
128 Posts
It looks as though some combination of dumbness between myself and a previous owner has left me with both of the clutch slave cylinder bolt holes stripped out. I guess that explains the weird shifting.
Is there a way to fix this w/o removing the transmission?
Thanks!
Posted on: 2010/11/6 19:52
pr0zac Re: Clutch slave bolt holes stripped
just tap it the next size bigger. drill the holes on the slave if needed
Posted on: 2010/11/6 20:11
Dale1990 Re: Clutch slave bolt holes stripped
Conway, AR
128 Posts
Would I need to drill the holes in the housing to tap them to the next size? I'm not sure there is enough room to get a drill in there.
Posted on: 2010/11/6 20:30
bogus Re: Clutch slave bolt holes stripped
you may need a 90* angle drill.
Posted on: 2010/11/6 21:56
Conway, AR
128 Posts
I'll give that shot. Thanks all!
Posted on: 2010/11/8 20:42
86 Coupe: SR 383
90 Convertible: Stock L98
06 Z06: Stock LS7
