Dale1990 | Clutch slave bolt holes stripped | ||
86 4+3
It looks as though some combination of dumbness between myself and a previous owner has left me with both of the clutch slave cylinder bolt holes stripped out. I guess that explains the weird shifting. Is there a way to fix this w/o removing the transmission? Thanks! |
Posted on: 2010/11/6 19:52
pr0zac | Re: Clutch slave bolt holes stripped | ||
just tap it the next size bigger. drill the holes on the slave if needed
Posted on: 2010/11/6 20:11
Dale1990 | Re: Clutch slave bolt holes stripped | ||
Would I need to drill the holes in the housing to tap them to the next size? I'm not sure there is enough room to get a drill in there. |
Posted on: 2010/11/6 20:30
bogus | Re: Clutch slave bolt holes stripped | ||
you may need a 90* angle drill.
Posted on: 2010/11/6 21:56
I'll give that shot. Thanks all!
Posted on: 2010/11/8 20:42
86 Coupe: SR 383 90 Convertible: Stock L98 06 Z06: Stock LS7 |
