213 user(s) are online (165 user(s) are browsing Forums)
Does it work?
92LRC Possible Fuel Pump issue
Weston, FL
88 Posts
Last few times I've had the car out it stalls when I go around a corner too hard. It just dies quietly and I can get it to turn over again but it will only run for a second. It kind of sputters and almost seems like it's struggling to get fuel. After a while it starts up again like nothing happened. I started thinking it might be the fuel pump or the strainer sock.
When I run the car easy (no sharp turns) it runs fine, no stalls. But lets face it this car was made to take sharp turns so......
Any input is appreciated. Thanks
Posted on: 2011/1/18 4:03
Steve40th Re: Possible Fuel Pump issue
1114 Posts
C4's are known for fuel loss on cornering. If you have over a 1/4 tank you shouldnt have this problem. Below it, its common when cornering hard , especially autocrossing etc.
Posted on: 2011/1/18 4:22
Ko'u ohana aia ku'a ikaika
bogus Re: Possible Fuel Pump issue
I had this when turning to the left, only. It did it a couple of times, then never did it again. Never figured that one out... and at the time, I had a nearly full tank.
Posted on: 2011/1/18 8:37
92LRC Re: Possible Fuel Pump issue
Weston, FL
88 Posts
You know, now that you mention it, I think it's always happened on a left turn. Funny.
Both times that it happened I probably had about 1/4 or just short. But let's say that it happens on a full tank, like what Bogus described, could it be the sock? Car has 114K and the pump and related gear are likely original.
I guess it's time to renew AAA and test out the theory (that is when the ice and snow goes away). I can't wait to move back to South Florida.
Thanks for the info.
Posted on: 2011/1/18 12:26
1114 Posts
Pumps are pretty reliable. The sock could (okay it is black and nasty). Takes about an hour to take it out and change.
Posted on: 2011/1/18 15:02
The pumps are reliable? Steve, where do you get your pumps, fill me in on this wonderful land of reliable fuel pumps!
I have been making a gnarly habit of needing a new FP about every 2.5 years... and I am not one to go down to empty! Then again, my gas gauge so doesn't work that I have no clue where empty is.
Posted on: 2011/1/18 17:05
1114 Posts
I just threw a pump away. Oh well, sorry about that. I bought a Racetronix. Cheap, compared to dealer, and provides enough fuel for my engine as the factory one was not enough with the 42# injectors.
Shouldnt be going through pumps that often.IMHO
Posted on: 2011/1/18 19:57
Weston, FL
88 Posts
Doesn't seem worth doing just the sock. If I'm gonna replace I'll get the racetronix kit that has a pump, sock, and all the hardware. It kinda seems that this is where I'm heading.
Posted on: 2011/1/19 0:24
1114 Posts
When you get the racetronix pump, ensure you have the correct sock. They sent me the wrong one. No biggie. It was a stock FORD MUSTANG GT 5.0 fuel pump sock, and fuel pump.... 255 lph
http://www.racetronix.biz/index.asp?F ... 4&url=IND&iFromFeatured=1
Posted on: 2011/1/19 0:28
Ultraman Re: Possible Fuel Pump issue
14751 Posts
I just bought a racetonix 190 lph kit and wondered when I saw the sock if it was the right one. what are they supposed to look like? This one is about 4 inches long and flat.
Posted on: 2011/1/19 4:03
1114 Posts
As long as it fits on the pump. You will know if it is wrong. If it is correct it slips right on.
Posted on: 2011/1/19 4:04
14751 Posts
Never mind I just looked at the picture. That's the one I have.
Posted on: 2011/1/19 4:05
