258 user(s) are online (200 user(s) are browsing Forums)
1st Gear: 2.74
2nd Gear: 1.57
4th Gear: 0.67
Reverse: 2.06
jaa1992 Need Wiring help - LT1
Stone Mtn, GA (near Atlanta)
187 Posts
I'm dropping a 383 into my 92 and we have a wiring issue.
The wiring from the opti to the harness going to the ECM is my latest issue. The 92 has a squareish connector with 4 wires in it.
The original wiring harness from the opti to this connector is long gone.
I had a Dynaspark opti on it that required splicing the old connector to the harness from the Dynaspark. Tried to get the opti harness from chevy - its discontinued. Only harness available was from a 95/96 which has a different connector and wire color scheme.
I don't have my 92 FSM - its at the shop with the car so I don't know which wires are which on the 92 ECM connector. I don't have an FSM for the 95 or 96 to determine what wires are which.
Has ANYONE looked at this and figured out which color wires from the later opti harness match up with the wire colors for the old opti harness?
Thanks in advance!
Posted on: 2011/1/27 23:56
pr0zac Re: Need Wiring help - LT1
You can get either the new style or old style harness on ebay.
Posted on: 2011/1/28 1:11
jaa1992 Re: Need Wiring help - LT1
187 Posts
eBay and I have a mutal agreement that we will never do business again
Posted on: 2011/1/28 1:21
Try tpiparts.net
Posted on: 2011/1/28 1:23
187 Posts
pr0zac wrote:
Try tpiparts.net
Nope, they have only the new style connector
Posted on: 2011/1/28 1:39
vetteoz Re: Need Wiring help - LT1
Posted on: 2011/1/28 1:49
Rockauto? I am not at home at the moment so I can't help you out. Check on ebay and see if the sellers have a website.
187 Posts
Posted on: 2011/1/28 2:00
bogus Re: Need Wiring help - LT1
yea, the new style, versus the old style, A still = A and B still = B... The only one not used on the new is the shield.
Posted on: 2011/1/28 6:13
