ITHZ | Can someone test my MAF for ME? | ||
A while back my '87 a4 vette crapped out on me with a code 33 (MAF Voltage too high).Since then I have been dumpping $$$ in my truck and now it's the vettes turn.Either the MAF is bad,or I have heard of bad ECM's causing this problems.By the FSM diagnostics it leads to a bad MAF.I want to send someone my MAF that can test it on there car and let me know its bad.I tried on the CF to hook up with someone local to test this(but did not work out).I really dont want to buy a new MAF if it is the ECM.
I will pay shipping both ways. |
Posted on: 2008/1/24 4:30
CFI-EFI | Re: Can someone test my MAF for ME? | ||
By the FSM diagnostics it leads to a bad MAF.I want to send someone my MAF that can test it on there car and let me know its bad. RACE ON!!! |
Posted on: 2008/1/24 19:47
ITHZ | Re: Can someone test my MAF for ME? | ||
Quote: Tried that could not find anyone in my area "WILLING".So if I send it to someone and they have no problems,then I'm not out $300-400 bucks. |
Posted on: 2008/1/24 22:17
tobijohn | RE:Can someone test my MAF for ME? | ||
WIll a 96 LT4 do as a test subject or does it have to be a L98 Vette from before 90-93 speed density period?
Posted on: 2008/1/24 22:50
ITHZ | RE:Can someone test my MAF for ME? | ||
'96 LT4 will not do it.Has to be an'85-89 L98.
Posted on: 2008/1/25 1:21
'96 LT4 will not do it.Has to be an'85-89 L98. I just remembered that I know someone who just picked up an 86 a couple of weeks ago. Let me contact him and see if he can help you out... |
Posted on: 2008/1/25 2:06
Woodstock | RE:Can someone test my MAF for ME? | ||
You would be better off, if you could find someone with an 86 or 87.
88 and 89 are somewhat different, but 85 won't work at all. One is made by Delco the other by Bosch and these have complete different values, by which they measure airflow. |
Posted on: 2008/1/25 2:20
91 convertible |
j3studio | Re: Can someone test my MAF for ME? | ||
There are a bunch of steps in the FSM before you get to here, right? I'm not positive, not having a MAF car. I think there many more MAFs replaced than there are bad MAFs. Many more ECMs, too. I have heard of subbing one on the car from either another Corvette, or even an F body. Maybe a friend has... I agree that there are many replaced that shouldn't but I've also seen many other steps taken (per FSM) when the problem turns out to be the MAF. They're touchy things, throwing codes when they shouldn't and not throwing codes when they should ... |
Posted on: 2008/1/25 4:20
Crazy8 | RE:Can someone test my MAF for ME? | ||
I can help you out. I am the friend of Tobijohn's that he refered to above. I just picked up an 86 A4, so I can test it out for you. PM me and I'll give you my address. May take me some time, as I have the interior pulled apart, right now. How quickly do you need it tested? Does this throw the code immediately upon start-up? If it is doing it on start-up, then I can test it quicker. If it needs to be driven to get the code to come up, then I'd need some time. BTW...I am located in South Florida. Let me know.
Posted on: 2008/1/25 14:21
2008 Corvette - JSB, 3LT, Z51, NPP, U3U, A6 1986 Corvette - For Sale...PM me for info 1986 Monte Carlo SS - 400hp 2007 Dodge Charger Daytona R/T - Plum Crazy #981 of 1400 |
Crazy8 I'll tale you up on that.I'm in no big hurry either.I currently have my motor and tranny out of my truck replacing my clutch,oil pump,water pump,timing belt,front seal,and motor mounts.I'll PM you soon.And thank you.
Posted on: 2008/1/26 8:04
My pleasure. Just shoot me a PM when you are ready. :thumbleft:
Posted on: 2008/1/28 17:13
