130 user(s) are online (93 user(s) are browsing Forums)
TimoG 87 C4 tire availability question
Gardnerville, NV
24 Posts
Our C4 'vert (with Z52 option) wants new shoes pretty badly, but after hitting up the usual websites (TireRack.com etc) and phoning a couple of local tire dealers, it seems the stock tires (255/50/16) aren't readily available unless I buy either drag radials or Toyo RA-1s for a ludicrous amount of money. RA-1s would be a waste, this car only sees the track through the fence...
It seems that at the moment, you're either looking at BFG gForce Sports or Falken ZE-512s in that size, both are showing on back order with no ETA for the local tire places...
Anybody got a recommendation what other tire brands to look for? Alternatively, if I try to run later C4 wheels I know I need spacers, but do those with the later stock tire sizes fit OK otherwise or do I risk rubbing issues?
We clearly don't have enough working cars at the moment .
Posted on: 2011/4/6 23:34
Matatk Re: 87 C4 tire availability question
Tim -
We just had a recent post on this, basically the same info you're saying:
http://www.corvette-guru.com/modules/ ... id=158932#forumpost158932
BFG is about your choice in a 16" rim.
If you want to step up to a 17" rim, I'd look for a used set of aftermarket a-molds or similar that matches your backspacing, then you don't need adapters. If you choose to go with later c4/c5 rims that have the later offset, you want to use adapters as opposed to spacers.
You should not experience any rubbing or fitment issues with later wheels other than that. You will want to pick the appropriate tire height to match your speedometer to you previous sized tires. Kevin has a calculator for that on his website.
Posted on: 2011/4/6 23:45
TimoG Re: 87 C4 tire availability question
Gardnerville, NV
24 Posts
Matthew,
apologies for re-asking that question, for some reason I must have overlooked the thread you linked to in the search results. Only managed to dig out older threads that also recommended the BFG.
Guess I'll see if I can find a set of 17s for a reasonable price unless the tires suddenly become available again.
Posted on: 2011/4/6 23:49
'87 Z52 Convertible with the wrong sort of gearbox, about as standard as they come.
No problem....I am not the search police, trust me! Just wanted to point that out in case you missed it.
Here's a set in your correct offset if you have an extra 700 clams.....geeze.
http://cgi.ebay.com/ebaymotors/84-85- ... ories&hash=item35aeb9b0f6
17x9.5 38mm offset
I'd look on CL and see if anything pops up.
Posted on: 2011/4/6 23:54
Gardnerville, NV
24 Posts
Well, a set of late C4 wheels have turned up locally for a lot less, probably even once I factor in the adaptors.
Summit Racing is actually showing the gForce to be available again towards the end of May and the Ze-512 (which I have on there now) as available, too. Although I'd prefer to call them first to check up on that one.
Posted on: 2011/4/6 23:57
BillH Re: 87 C4 tire availability question
The 17 in. choices ain't what they used to be either.
Posted on: 2011/4/7 0:04
Gardnerville, NV
24 Posts
That's not really reassuring .
I would like to stay with the 16" as the car is pretty original as is and I'd like to keep it that way.
Posted on: 2011/4/7 0:05
Another option, although not necessarily the most popular is to run 245/50r16. It will be slightly smaller in width and slightly less in diameter, but will be close:
http://www.miata.net/garage/tirecalc.html
You can find those tires very reasonably priced, under $100 each. Not necessarily "z" rated, but are you driving 150 mph?
ps - another calculator:
http://www.1010tires.com/tiresizecalculator.asp
Posted on: 2011/4/7 0:22
Gardnerville, NV
24 Posts
That size had been mentioned to me on another board (GRM), but someone on there also pointed out that Discount Tire supposedly has gForces for a 2-3 day delivery. Time to give them a call and see...
Posted on: 2011/4/7 0:24
76Nordic Re: 87 C4 tire availability question
Dumbass
Brea, CA
239 Posts
That is what I have on my 84, the 245/50r16. Is that what was stock on an 84, or were these downsized also? They look to me that they might be stockers. Just curious. Mark
Posted on: 2011/4/7 2:58
The Definition of insanity; Doing the same thing over and over again, and expecting different results.....Einstein
CentralCoaster Re: 87 C4 tire availability question
Good question. I know the Z51s with 9.5" wheel came with 255s, but am not sure about the 8.5" wheel. An 8.5 can accomodate a 255 just fine. A 9.5 can handle up to a 285 or so.
Posted on: 2011/4/7 4:00
Gardnerville, NV
24 Posts
The Z52 should have the same 9.5" wheels as the Z51, but the PO replaced the wheels with refurbished ones so I have to check if he put 8.5" or 9.5" wheels on...
Posted on: 2011/4/7 13:19
