128 user(s) are online (86 user(s) are browsing Forums)
1969 through 1976 Corvette.
Crazy8 Need pics 6 pt cage w/ racing seats
Lake Worth, FL
125 Posts
I am trying to figure out if I can put a 6 point cage in my 86 with Corbeau A4 seats. When I test fitted my seats in the car, I can't see how I could have the cage in, without having my ribs up against the cage. May have to re-think whether I want a car in the 10's or upper 11's. So, any pictures of how your 6 point cage runs along the seats/doors would be great. Thanks in advance.
Posted on: 2008/1/25 15:59
2008 Corvette - JSB, 3LT, Z51, NPP, U3U, A6
1986 Corvette - For Sale...PM me for info
1986 Monte Carlo SS - 400hp
2007 Dodge Charger Daytona R/T - Plum Crazy #981 of 1400
SpectatorRacing Re: Need pics 6 pt cage w/ racing seats
I have lots...I'll post some later tonight as I don't have access to photobucket during the day.
Or PM me your email, I have a few here, although they focus on the attachment points.
Posted on: 2008/1/25 16:21
CFI-EFI Re: Need pics 6 pt cage w/ racing seats
Top of Utah
372 Posts
There is a big difference between "10's" and "upper 11's" With a coupe, you need no bars until you dip under 11.00. Then you need a roll BAR, (5 or 6 points) which is good down to 10.00. Below 10.00 (in a coupe) you will need a roll CAGE. A CAGE has 8, and most likely, more "points". If it turns out you have a convertible, I can give you the ET requirements for both the bar and the cage for it, too.
RACE ON!!!
Posted on: 2008/1/25 16:49
Crazy8 RE:Need pics 6 pt cage w/ racing seats
Lake Worth, FL
125 Posts
For the series that I run, if you go below 11.49 in the quarter, you need a 5 or 6 point roll bar. Once you are below 10's, yes you need a cage. I just generalized the terms. Since I don't think I have the room for a 6 point roll bar without giving up too much comfort (also plan on driving the car around), I may have to focus on just getting enough power to be in the 11.6 second range.
Posted on: 2008/1/25 17:04
RACE ON!!!
How do you get 8 mounting points on a Corvette? Go though the firewall into the front suspension?
I don't know drag racing rules, but the road racing cages have six points - a main hoop, two bars that extend rearward, and two bars that exted along the roof and down to the floor below the dash. Obviuosly there are multiple structural bars between the main frame, but they don't actually hit the vehicle frame.
Going through the firewall would add stiffness, but not much safety.
Posted on: 2008/1/25 18:30
Top of Utah
372 Posts
How do you get 8 mounting points on a Corvette? Go though the firewall into the front suspension?.
Often. The pic shows what CAN be fitted inside of the cabin. Many cages have bars on either side of the car that run forward of where the red cross bar, that I have drawn, in meets the front down bars, through the firewall and ties into the front frame.
THAT describes a roll BAR. What distinguishes a BAR from a CAGE is that a BAR is a hoop, as you described, with the appropriate bracing.. A CAGE has a halo, that surrounds the driver and is tied to the frame. The halo, in my pic, is supported by a hoop in the rear and the front downbars in the front.
RACE ON!!!
Posted on: 2008/1/25 19:47
SpectatorRacing RE:Need pics 6 pt cage w/ racing seats
The cage I have is exactly what you have shown in the picture with a few exceptions - My front lower attachements do penetrate the firewall and attach to the vehicle frame about 6 inches forward of the firewall.
I don't have the bars that come off of the crossbar behind the driver and appear to go nowhere...
I also have a diagonal bar in the halo which goes from the driver front to passenger rear.
And lastly I have NASCAR door bars, two parallel bars which go into the door frame out to the outer skin.
In my description in the earlier post I only referenced the attachment points to the frame, of course we have requirements for the halo, etc. Although strangely, the crossbar along the inside of the firewall under the dash is not required, but just about everyone has one.
So I'm still unclear - where is the 7th and 8th attachment point? Those two bars off the crossmember behind the driver? To what do they attach in a vette, there's just the fiberglass tub at that location...
Unless we're talking about different things when we say 6 or 8 points. I consider a "point" to be an attachment to the vehicle frame.
Posted on: 2008/1/25 20:25
CFI-EFI RE:Need pics 6 pt cage w/ racing seats
Top of Utah
372 Posts
We do agree on the definition of a "point". That is a generic pic, I "borrowed" from somewhere to show the difference between a bar and a cage. It isn't Corvette specific. A cross member could be fabricated to accept the mystery bars you refer to. Without the "mystery bars", but WITH the through the firewall bars, you have 8 points. I am not a chassis builder. I am just trying to help with some basic definitions and NHRA requirements. If necessary, I CAN study up on them.
RACE ON!!!
Posted on: 2008/1/26 1:24
I don't think that'll be necessary...
It looks like the rules are basically the same between drag and open track, with the possible exception of door bars. Although I've heard that drag cars were beginning to use double bars as well, is there a possible rule change coming up for that, or is side impact still considered rare?
Posted on: 2008/1/26 17:58
