232 user(s) are online (170 user(s) are browsing Forums)
« 1 (2)
JeffK Re: Roller Rocker issue
High Point, NC
1440 Posts
Well, I'll be trying to adjust the valves again tonight. Apparently either I'm a moron or this car just hates me.
Runs great though. The idle is way smoother with the new lifters.
Posted on: 2011/4/19 20:32
Matatk Re: Roller Rocker issue
Glad to hear the lifters are in. Look on the bright side, you'll be a professional valve lash setter by this time it's over.
Posted on: 2011/4/20 1:43
High Point, NC
1440 Posts
Haha. If only it would stop the ticking. I'd be fine doing it. I redid them again tonight at +3/4 turn. Still no bueno. My buddy that was helping me said the now it doesn't sound like it is a engine noise.
I've already checked the header bolts. I am going to double check the collector bolts tomorrow night.
Posted on: 2011/4/20 2:05
What header bolts are you using? I used stainless steel cap bolts with locking washers...no leaks, no backing out.
Posted on: 2011/4/20 2:17
High Point, NC
1440 Posts
I'm using stainless allen heads with lock washers on the flanges and the collector bolts that Hedman supplied.
Posted on: 2011/4/20 11:15
Have they backed out at all? What length are they?
I checked mine after more than 500 miles and they hadn't moved a mm.
I'm also using Percy's gaskets.
Posted on: 2011/4/20 11:32
High Point, NC
1440 Posts
None of them were loose on the flanges. I'm using Percy's too.
Posted on: 2011/4/20 14:09
« 1 (2)
