Browsing this Thread:
2 Anonymous Users
JeffK | Re: Roller Rocker issue | ||
Well, I'll be trying to adjust the valves again tonight. Apparently either I'm a moron or this car just hates me.
Runs great though. The idle is way smoother with the new lifters. |
Posted on: 2011/4/19 20:32
Matatk | Re: Roller Rocker issue | ||
Glad to hear the lifters are in. Look on the bright side, you'll be a professional valve lash setter by this time it's over. |
Posted on: 2011/4/20 1:43
Haha. If only it would stop the ticking. I'd be fine doing it. I redid them again tonight at +3/4 turn. Still no bueno. My buddy that was helping me said the now it doesn't sound like it is a engine noise.
I've already checked the header bolts. I am going to double check the collector bolts tomorrow night. |
Posted on: 2011/4/20 2:05
What header bolts are you using? I used stainless steel cap bolts with locking washers...no leaks, no backing out.
Posted on: 2011/4/20 2:17
I'm using stainless allen heads with lock washers on the flanges and the collector bolts that Hedman supplied.
Posted on: 2011/4/20 11:15
Have they backed out at all? What length are they?
I checked mine after more than 500 miles and they hadn't moved a mm. I'm also using Percy's gaskets. Matthew |
Posted on: 2011/4/20 11:32
None of them were loose on the flanges. I'm using Percy's too.
Posted on: 2011/4/20 14:09
