171 user(s) are online (125 user(s) are browsing Forums)
Notorious General Chevy V8 bore & stroke dimensions
Something for your bookmarks.
Specs
Posted on: 2008/1/26 2:51
tobijohn RE:General Chevy V8 bore & stroke dimensions
Palm Beach Gardens, FL
515 Posts
That reminds me of something I've been meaning to ask. What's the biggest (c.i. wise) you can safely go with the LTx block?
Posted on: 2008/1/26 4:08
Notorious RE:General Chevy V8 bore & stroke dimensions
SonnyinVa has a 409 LT4. I've heard of standard SBC combos as large as 454.
Posted on: 2008/1/26 4:10
515 Posts
Thanks, any idea where I could get more info on the 409? And any reason you couldn't go higher with the LTx? And if you could, any reason you wouldn't want to?
Posted on: 2008/1/26 4:29
The main reason is, that there was never an LTx block with larger than a 4.00" standard bore. Whereas the Gen I 400 block has a 4.125" standard bore.
Posted on: 2008/1/26 4:32
515 Posts
I know cylinder wall thickness is a factor but can't most blocks be bored out a bit? Well, after typing my reply, I thought I'd get my lazy fingers to do a little work and this is something I found (in case anyone other than me is interested):
http://www.thirdgen.org/techboard/eng ... stroking-lt1-how-big.html
Posted on: 2008/1/26 13:56
Certainly but I mentioned their factory bores as a starting point. The 1/8" larger bore of a 400 block gives it substantially more displacement capability than an LTx or any other 350 block.
Posted on: 2008/1/26 14:05
515 Posts
So then as far as dispacement cost is concerned it's a cheaper build to start with the 400, right?
Posted on: 2008/1/26 14:09
If you're still talking an LTx build though, the 400 block isn't usable with it.
Posted on: 2008/1/26 14:13
BrianCunningham RE:General Chevy V8 bore & stroke dimensions
Largest I heard with a stock block is a 421ci.
The walls are real thin though, so you'll need to shop around
With long strokes you need to run a reduced base circle cam.
Here's a good pic to keep in mind.
Posted on: 2008/1/26 20:09
CasetheCorvetteman RE:General Chevy V8 bore & stroke dimensions
Yes, 421 is the biggest ive seen as well, was in VETTE magazine many moons ago, red one, 1,000 horse daily driver, "Retched Excess" written on the front cover i think
Posted on: 2008/1/27 5:32
