175 user(s) are online (116 user(s) are browsing Forums)
1st Gear: 2.48
2nd Gear: 1.48
- 13 Bolt ...
bjz intake bolt size
61 Posts
Ok I have a little bit of a problem. Ordered some intake base bolts based on a chart of sizes I found on this forum. The sockets cap is noticeably shorter. Will it be ok or time to re-order longer ones.
jpg  th_650932431_photobucket_58250_.jpg (1.57 KB)
2764_4dbeae2e5b8a9.jpg 90X160 px
Posted on: 2011/5/2 13:13
Durango_Boy Re: intake bolt size
It's fine. Run it in with the anti seize goo and make sure you torque to spec in the correct sequence.
Posted on: 2011/5/2 16:29
bogus Re: intake bolt size
20860 Posts
3/8-16 is the diameter. A marginal difference in length won't matter.
I would not use anti-sieze. It will skew the actual torque at the thread and potentially cause damage to the aluminum. For example, if you have a 30 ft-lb requirement, dry, then expect anti-seize to increase that 40% at the thread!!! That's how slippery that stuff is. Your 30 ft-lb becomes over 40 ft-lb! Not good for those soft aluminum threads.
There isn't enough stuff going on there to cause the aluminum to react to the stainless. I have never had that problem.
Posted on: 2011/5/2 17:56
That is a very good point about the anti seize affecting torque readings. It does come down to manufacturer though.
A study...wish I still had the link, showed the 4 most popular manufacturers and how they affected torque readings.
If I recall, Moly made one that didn't change the torque reading at all using the 3 step process. The others all overshot the target by landslides using the 3 step method.
The one thing I will say, all hit their targets on a one step torque process, and with an intake bolt, that's all that's needed.
Posted on: 2011/5/2 18:47
josephf31 Re: intake bolt size
New Jersey
375 Posts
Not to change the topic, but can you provide a link to where you found the chart of bolt sizes? I searched but didn't see anything and that would be useful...thanks!
Joe
Posted on: 2011/5/2 19:01
20860 Posts
Check CentralCoasters sig link. I think it's there.
He was the one who compiled the list.
Posted on: 2011/5/2 19:40
BillH Re: intake bolt size
Durango_Boy wrote:
[A study...wish I still had the link, showed the 4 most popular manufacturers and how they affected torque readings.
Yea, I wish you had that link DB. I must say, I'm very skeptical on the Moly thing.
Everybody should have the ARP book in their garage, it's free. You can get a pretty good idea of percentages from their chart dry vs oil vs ARP lube.
Posted on: 2011/5/3 0:40
