133 user(s) are online (78 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
matts85vet how can i make a tcc lockup switch?
Toledo, Ohio
58 Posts
i would like to make a switch that would lock up my torque converter for freeway driving.
so far i have tried a switch that grounds the f pin on the diagnostic link, but i dont think it works.
any suggestions?
Posted on: 2011/6/13 16:23
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x-
bogus Re: how can i make a tcc lockup switch?
Posted on: 2011/6/17 0:34
matts85vet Re: how can i make a tcc lockup switch?
Toledo, Ohio
58 Posts
thanks for the response and the links!
i have a switch that connects the A pin - black w/white stripe,and the f pin - brown w/black stripe from the aldl.
i tested the switch, it's good.
but it doesn't do anything.
ill try replacing the stoplight switch and see if that does anything, as that's where the power into the solenoid flows through. maybe it's bad and the solenoid isn't getting power.
Posted on: 2011/6/18 1:16
Matatk Re: how can i make a tcc lockup switch?
22810 Posts
How did you test it to verify the switch was/wasn't working at unlocking the tcc?
Posted on: 2011/6/18 2:48
Toledo, Ohio
58 Posts
the switch measures zero ohms when switched
zero ohms between pin a and f
no change in engine rpm when switch is thrown
cannot feel the converter locking up
i think it may be the brake switch w/ the vac line-it has 2 wires pink and purple
Posted on: 2011/6/18 18:34
62panshovel Re: how can i make a tcc lockup switch?
United States
33 Posts
you can test it at the aldl without the car running and hear it click... you should be using a test light btw as the f is the return path of voltage. It will be lit if the brake switch is good. The ECM provides a ground path. When driving the test light plugged in f will go out when the ECM closes the circuit to lock it up...
Posted on: 2011/6/18 22:19
Toledo, Ohio
58 Posts
i dont have a test light, but i do have a multimeter, so ill check the voltage at the aldl and at the brake switch.
thanks for the suggestion!
Posted on: 2011/6/19 0:20
j3studio Re: how can i make a tcc lockup switch?
Welcome to another 1985!
Posted on: 2011/6/19 1:01
22810 Posts
Have you tried a simple jumper wire at the aldl port to see if that works? If so, that means the switch isn't working.
Posted on: 2011/6/19 2:53
Toledo, Ohio
58 Posts
i checked the voltage between a and f with koeo--12v.
when brake peddle was pressed--0v.
so i guess the switch is ok.
ill try the jumper wire -paperclip- and see if that does anything.
if not, it must be the connector at the tcc solenoid or the solenoid itself-how hard is it to replace the solenoid?
the trans was rebuilt 2 years ago-is the tcc solenoid normally checked and replaced?
Posted on: 2011/6/19 17:38
Toledo, Ohio
58 Posts
tried the paperclip on a and f with koeo-no click.
so i guess its the solenoid
Posted on: 2011/6/19 20:37
22810 Posts
AFAIK the solenoid switch isn't replaced with a rebuild. I'll have to look in the fsm for the testing procedure.
Posted on: 2011/6/19 21:42
United States
33 Posts
Run a wire from the battery negative or the seat frame and koeo plug it into f. Not sure I trust pin "A" for ground sourcing. You should hear it click. Changing it is easy though. A couple 10mm bolts hold it in. You can get it with the harness or the cheaper one you splice in. There is also a fourth gear pressure switch wired into the harness. FSM has Chart C-8A for diagnostic testing. Did you drive it and see the light go out (voltage between f and ground "not A" = 0v)when the car is at temp and running steady in fourth gear?
Posted on: 2011/6/20 0:17
Toledo, Ohio
58 Posts
i don't have a test light so ill have to get one and drive around and see.
i thought if there was 12v between a and f then the circuit and wiring was good, as this would be the only way that could happen.
ill try with the pin f and a different ground source and see if that does anything
Posted on: 2011/6/20 0:39
