216 user(s) are online (175 user(s) are browsing Forums)
Ramrod Quick EGR Check
S. California
296 Posts
I got an EGR code, lots of variable to check. So I did a quick vacuum check on the EGR, hear some hissing but was not sure if it was bad. I bought a new one and did the vacuum check and the diaphragm actually moves enough to see and feel. New EGR was $54.00
Posted on: 2008/2/3 15:38
MK 82 RE:Quick EGR Check
Palm Beach Gardens, FL
439 Posts
Do you have a question?
Posted on: 2008/2/3 16:07
96 CE Roadster LT4
Ramrod RE:Quick EGR Check
S. California
296 Posts
Naw, just a FYI to determine EGR valve operation, I'm sure there are more techincal methods, but for the average joe, Put a hose on the EGR nipple, suck, and watch for movement.
Posted on: 2008/2/3 16:20
