144 user(s) are online (90 user(s) are browsing Forums)
[IMG]http:/...
istter1 Painting strip around windshield
Bakersfield Ca
2336 Posts
Is there a simple way and a type of paint to paint this strip with out masking off vehicle? It is mainly a touchup.
Steve
jpg  black strip.jpg (153.77 KB)
5144_4eceec3d53b4f.jpg 2048X1536 px
Posted on: 2011/11/25 1:18
Carol Burnett
bogus Re: Painting strip around windshield
nope... not really.
I did it on the windshield. Was more annoying than hard.
Take the top off, that's the best bet. Use some wide - 2" - painters tape to cover the glass, then cover the glass with paper.
Using some cleaner and a Scotch-Brite pad to clean off the goo. Then hit with some paint prep cleaner. Dry off, prime, set, color. I would use satin or semi-gloss black. Rattle cans dry very quickly, so debris isn't that much of a concern. I recommend a sunny view, it will warm the metal and allow the paint to set faster. I also used engine paint. Much stronger than regular paint.
And it is well worth doing right.
Posted on: 2011/11/25 1:53
istter1 Re: Painting strip around windshield
Bakersfield Ca
2336 Posts
nope... not really.
Thanks Andy that is the way I thought it would have to be done.
Steve
Posted on: 2011/11/25 1:59
Carol Burnett
BillH Re: Painting strip around windshield
You can't touch up satin black easily cause there's 10+ shades of satin black (and I have most of em in the shop .
I'll deviate a bit from what Andy said (but his way works too).
1. Wash the molding with a heavy concentrate of Dawn & water. This removes any wax.
2. Scotchbrite will work OK but if there's paint missing in a larger area (like a stone chip) the edges will show up when you paint. These should be "feather edged" with 600 paper done wet, light pressure on the paper.
Wash again with dawn & water.
2. Use paint prep (automotive) one wet rag followed up immediately with a dry rag.
3. You can warm up the molding in the sun but don't get it too hot or the paint will dry too fast. If it feels hot to your fingers, it's too hot.
Now, wipe off the fingerprints where you touched it with paint prep.
4. I have a boatload of "painters blue tape" in the shop, I NEVER use it for painting the edges leak like a mofo.
Walmart just started carrying 3m green automotive masking tape in the auto section, it has a crisp edge and doesn't leak.
5. The best paint is SEM Trim Black, no primer required and is very close to OEM.
Posted on: 2011/11/25 13:48
Bakersfield Ca
2336 Posts
Thanks Bill. When I get back from the Beach Sunday I will give it a shot. The only thing I don't have right now is the paint. There has to be someone here in Pismo Beach that carries it.
Steve
Posted on: 2011/11/25 15:20
Carol Burnett
Steve
http://sem.ws/Suppliers2.asp?state=CA&p=1
Posted on: 2011/11/25 15:52
Bakersfield Ca
2336 Posts
BillH wrote:
Steve
Some list Bill. Two places within 10 miles of me here at the beach.
Thanks
Steve
Posted on: 2011/11/25 16:40
Carol Burnett
http://sem.ws/Catalog.asp?prod=133
Note: This stuff is very stinky. Wear a respirator if you have one.
Posted on: 2011/11/25 18:40
Or use it outside?
Posted on: 2011/11/25 18:55
Or use it outside?
I'd say even outside.
Same with their interior trim paint.
But (IMO) this is pro stuff, high quality. Maybe that's why you don't see it in the regular stores.
Note: The product web site mentions Low VOC available. Might be worth a try.
Posted on: 2011/11/25 20:12
I wonder if its even legal in SoCal... we have such tight laws about that stuff here.
Posted on: 2011/11/25 20:19
Well they do sell SEM in Bakersfield, no idea if it's only Lo Voc or whatever.
Posted on: 2011/11/25 20:26
Bakersfield Ca
2336 Posts
Well just got home from Pismo Beach. Too late to pick up paint today. I drive by D'Angelo's paint on the way to and on the way back from work. I will see what they have. Thanks Bill & Andy for your help. I do have several masks the cartriage may be old I can replace them or weare my old grasshopper Mace mask. God don't know if they still make those.
Steve
jpg  sem.jpg (347.19 KB)
5144_4ed2a96239948.jpg 2048X1536 px
Posted on: 2011/11/27 21:25
Carol Burnett
looks like a lovely day at the beach!
Posted on: 2011/11/28 4:03
Bakersfield Ca
2336 Posts
Almost 80 degrees and light breeze. This beach dosn't suck like the one in long beach when I live there in collegs. Seal Beach wasn't bad.
Steve
Posted on: 2011/11/28 4:21
Carol Burnett
Bakersfield Ca
2336 Posts
The paint isn't lo Voc
$12.26 w/tax At www.dangelospaint.com
When it warms up here I will paint . Only in the 50's all day.
Thanks guys
Steve
jpg  sem paint.jpg (214.90 KB)
5144_4ed42fbc6de06.jpg 1792X1344 px
Posted on: 2011/11/29 1:06
Carol Burnett
Same price as the catalogs.
Remember, the most important thing to a good paint job is prep.
Posted on: 2011/11/29 1:07
BTW, I was doing prep today, 2 pieces on the 67 steering column that are very noticeable when you're in the car, the piece that holds the column to the dash and the hub that the steering wheel mounts to.
They are cast aluminum and have a few really small nicks.
Took the old paint off by soda blasting.
Sanded with 600 then Scotchbrite.
Shot some primer, sanded with 600 wet.
Shot more primer, sanded with 600 wet.
Shot a 3rd primer coat and sanded woth 1000.
If they look OK in the sun light tomorrow, I'll shoot the satin black, if not one more primer coat.
Posted on: 2011/11/29 1:19
Bakersfield Ca
2336 Posts
Your right Bill it is not like painting Cotton Pickers. A big Farmer in the 70's Dutch Houtchin in Buttonwillow on Main Drain road got mad at John Deer and had me paint his 25 Cotton Pickers International Harvester Red. He wouldn't even let me wash them first.
I plan on doing this right.I have a lot of rolls of paint protection paper left over from painting my rental. I don't want to half ass this project.
Steve
Posted on: 2011/11/29 1:29
Carol Burnett
Too bad you're not closer, we could soda blast that in 10 min, well after taping it all up.
Posted on: 2011/11/29 3:18
Bakersfield Ca
2336 Posts
Thanks for the offer Bill. Last time I was in Reno A friend and I stayed in a place called Pollock Pines on the California side. Dam were we drunk for 5 days straight. The girls were hott up there. His grandmother was a pot growing hippie. The rooms were free and she fed us. LOL
Steve
Posted on: 2011/11/29 4:51
Carol Burnett
PLRX Re: Painting strip around windshield
SoCal
212 Posts
I would say that masking all around is the only way and it was the way I did mine.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/Interior/CELT4190.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/Interior/CELT4191.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/Interior/CELT4212.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/Interior/CELT4213.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/Interior/CELT4214.jpg[/IMG]
Posted on: 2011/12/4 20:29
Bakersfield Ca
2336 Posts
Thanks Pete! Well you answered a question for me about the hood. It was just painter after the front bumper was Damaged. How long did it take for the paint to dry. It has been in the low 50 and 60 here and fog. Waiting for a warmer day before painting.
Steve
Posted on: 2011/12/5 5:00
Carol Burnett
SoCal
212 Posts
I would wait for warmer weather. I let it seat for an hour after the third coat.
Posted on: 2011/12/5 5:55
Bakersfield Ca
2336 Posts
That was my guess
thanks Pete
Steve
Posted on: 2011/12/5 6:54
Carol Burnett
Yea, at least 70* below that = runs in the paint.
Make sure the paint is warm too. If the can feels cool/cold, stick it in the sink in wamn water. Wipe the can off, give it a couple of shakes, if the can feels the same temp as your hand, it's good.
Fog on the first coat.
Posted on: 2011/12/5 13:42
Bakersfield Ca
2336 Posts
May reach 65 this weekend The Bakersfiels story.
Posted on: 2011/12/5 19:11
Carol Burnett
Warm up the molding in the sun, the paint in the sink, you'll be OK.
I lay parts out in front of the garage in the sun until they feel warm and shoot them when it's 50* out.
It's just paint, even runs can be sanded out.
Posted on: 2011/12/5 19:15
Bakersfield Ca
2336 Posts
Thanks Bill for the confidence builder.
Steve
Posted on: 2011/12/5 23:04
Carol Burnett
Bill is right. This SoCal sun can be real warm even if the air isn't!
And Bills tips from above are excellent:
I have seen PLRX's 96, and the man does GREAT work. Exceptionally detail oriented. Simply an awesome looking car!
Posted on: 2011/12/7 5:00
Bakersfield Ca
2336 Posts
Hopeing it is nice enough this weekend to start on this project. Looks like it may warn up to 62 and the sun will be out.
Steve
Posted on: 2011/12/7 13:59
Carol Burnett
Bakersfield Ca
2336 Posts
I applied 4 coats of paint. Came out as a nice job.
Thanks for the help guys!!
5144_4ee3e8e22393f.jpg 2048X1536 px
jpg  trim7.jpg (308.61 KB)
5144_4ee3e924b9715.jpg 2048X1536 px
jpg  trim6.jpg (277.68 KB)
5144_4ee3e94cce26c.jpg 2048X1536 px
jpg  trim5.jpg (289.21 KB)
5144_4ee3e9780dfec.jpg 2048X1536 px
jpg  trim4.jpg (314.99 KB)
5144_4ee3e994b7e3f.jpg 2048X1536 px
jpg  trim3.jpg (327.09 KB)
5144_4ee3e9b017b6d.jpg 2048X1536 px
jpg  trim2.jpg (198.93 KB)
5144_4ee3e9c6ef46d.jpg 1792X1344 px
jpg  trim1.jpg (228.88 KB)
5144_4ee3e9df75eb5.jpg 1792X1344 px
Posted on: 2011/12/10 23:23
Lookin' good, Steve.
If you got any overspray on the rear window (or anywhere else) use a clay bar.
Posted on: 2011/12/11 0:08
Bakersfield Ca
2336 Posts
Thanks for the help Bill. I used an old bed sheet over the back half. No probles spotter yet. Only problem or mistake I made was I bought too much paint. Two cans. I will find a use for it. There were no leaks from the grean tape great advice.
Steve
On to the next project.
Posted on: 2011/12/11 1:12
Carol Burnett
Steve
OH, I C.
Well, the extra can is too hard to sell because of shipping.
You can never have enough black rattle cans in the garage. I have 7 or 8 of varying shades.
You could always paint your wroght iron around the house.
Posted on: 2011/12/11 1:25
Bakersfield Ca
2336 Posts
BillH wrote:
OH, I C.
I think my son is going to use it to paint his bumper on the Jeep.
Well it won't be waisted. Lol
Steve
Posted on: 2011/12/11 2:16
Carol Burnett
flyboy Re: Painting strip around windshield
Attention to detail. Nice work.
Posted on: 2011/12/11 2:28
Bakersfield Ca
2336 Posts
When people outline the project for you Joe, it makes it a lot eaiser to accomplish.
Lots of help on this site.
Steve
Posted on: 2011/12/11 2:58
Carol Burnett
