Browsing this Thread:
3 Anonymous Users
istter1 | FUEL RETURN LINE | ||
When my belt snapped it broke off the rubber hose at the FUEL RETURN LINE . I haven't run her down to the shop to put her up on the lift yet . Is there an easy way to remove the SS line so I can take it over and have another rubber line put on for me?
I don't feel like calling for a tow to get her to the shop. Steve |
Posted on: 2012/2/8 5:38
bogus | Re: FUEL RETURN LINE | ||
it should be a rubber hose to a bracket on what was the old fuel pump, that's where it hooks up. Shouldn't be but a 20 minute job.
Posted on: 2012/2/8 6:21
vetteoz | Re: FUEL RETURN LINE | ||
On my TPI cars ,the front fuel lines are 1 piece (combo of steel and rubber lines) from the fuel filter all the the way to the rails. You disconnect the return line at the coupling by the filter and pull the line out from the rear because it runs through a hole in the A/c bracket |
Posted on: 2012/2/8 12:39
istter1 | Re: FUEL RETURN LINE | ||
When you follow the lines down from the rails there is a small bracket to hold the lines in position is it hard to get to. I have been looking in the dark with a flash light. Other than that the pressure coupling is where the line was brocken off less than a 1/2" sticking out. Steve |
Posted on: 2012/2/8 13:27
marv02 | Re: FUEL RETURN LINE | ||
I had the Pressure fuel ilne go bad on me twice thats under the A/C pump I end up replacing Pressure and return line with Briaded steel hose from the fuel filter to Fuel rails.
I also ran the New hoses up next to the inside wheel well then over to the motor so if it ever starts leaking again you can see it and you can get to it with out removing the A/C pump to do so. The first 2 times it did leak you could smell you could see the gas under the car but you could not see the leak. The car wanted to die and Number 1 it a fire waiting to happen Fiberglass car go up very fast when they are are on fire. |
Posted on: 2012/2/8 13:45
383 4 bolt main (10.5 to 1) Balanced, Flat top , pistons LT-4 Hotcam, C C ultra pro magnum steel 1.6 RRA, Trick Flow Heads Super 23 (195 runners) 62cc , SPL runners, Hi Flow intake base, 24# FIC Bosch 3 Injectors, Chipped, Melrose full headers, 3 way Main |
So do you have to pull back the ac unit to get to the bracket to pull the line as they go down from the fuel rails to get them out? Steve |
Posted on: 2012/2/8 13:56
[quote]
marv02 wrote: I had the Pressure fuel ilne go bad on me twice thats under the A/C pump I end up replacing Pressure and return line with Briaded steel hose from the fuel filter to Fuel rails. I also ran the New hoses up next to the inside wheel well then over to the motor so if it ever starts leaking again you can see it and you can get to it with out removing the A/C pump to do so. quote] I like your idea of using the Briaded steel hose to replace those lines. Do you have a guestament of the legnth of line you used? When the other line broke the drivers cabin filled with gas fumes. It was like driving a bomb. The ease of replacing the old SS lines with the Briaded steel hose should help with any future problems. I have a three day weekend so sounds like an easy project when I start this sat. Thanks Steve |
Posted on: 2012/2/9 2:58
Here is the parts list I use to build my SS hose system.
It's not cheep when it all added up but it worth it in my eyes. I rather spend a little money now rather than be standing on the side of the HWY wacthing my car burn to the ground from a fuel leak that I could not see. At least this way if starts leaking all you have to do is pop the hood and find the leak very easy now. http://www.summitracing.com/parts/FRA-100106-BL/ http://www.summitracing.com/parts/FRA-112006-BL/ http://www.summitracing.com/parts/SUM-220009/ http://www.summitracing.com/parts/SUM-230610/ |
Posted on: 2012/2/10 2:54
Edited by marv02 on 2012/2/10 3:27:48 |
Here some pictures of the SS Fuel lines and yes they are tall valve covers.
http://s285.photobucket.com/albums/ll60/KTM06/Vett%20Fuel%20lines/ |
Posted on: 2012/2/10 3:19
I like the way they look. On my way home from work and we will be towing the vett to the shop. I will check with the local speed shop and see if those parta are in stock. Thanks Steve |
Posted on: 2012/2/10 22:48
I hope it helped you out Make sure you tie the SS braided line every couple inches if starts rubing on things it can act like a hack saw and cut it way though things.
There anouther way to run the fuel lines with Nylon braided hose. |
Posted on: 2012/2/11 1:09
I like the idea. I really disliked the gas spraying every where when the belt broke the line. This feels a lot safer. The best part is it will now be easy to get to. Have a three day weekend should be able to find parts here. Thanks again Steve |
Posted on: 2012/2/11 1:39
I could not beleive the price of these parts compaired to Summit. Three Speed shops in town and If it was the March meets I could get these parts for next to nothing from the same shops. What a rip. Monday I will hit one 4x4 shop and all the hydralic shops. If no luck I will be ordering from Summit.
Steve |
Posted on: 2012/2/12 5:36
LOL I know what you mean about prices Some times if you need it now you have to pay the high prices if you can wait online lot times is the way to go I beleive Summit parts come out of AZ so you should get them in a couple days.
If you do this Hose job you're self remember use some Masking tape and wrap tight around the Steel braided hose where you want to cut so it willn't fray as much. I also used a high speed cuting wheel with a high speed air grinder how I cut mine. Some time putting the ends fitting on the hoses can be a pain just take your time they do fit and you will end up poking you're fingers with the steel braid trust me. As for the nipple adapters your going to need 2 sets 1 for the fuel rails there other for the fuel filter and return line fitting under the car. I used the 120 degree fittings at the fuel rails and the straight at the filter area I think if i was going to do it again 45 degree could work a little better at the filter area just heads up. The Stock hard line has a mount attached to the cars frame rail where the A Arms are at is a Pain to get at but it can be done. I also made a custom mount about 7 inches in front of the fuel filter you can use some pipe clamps so yu can mout the hose to the frame to keep the hose away from the exhaust. http://www.google.com/imgres?q=adel+c ... tart=6&ndsp=18&ved=1t:429,r:6,s:6 http://www.google.com/imgres?q=adel+c ... tart=6&ndsp=18&ved=1t:429,r:3,s:6 I had my engine pulled out when I did mine I was sticking in my 383 at the time. The 2nd time the fuel line started to leak I pulled the motor at the same time ya thats alway been my problem LOL stats out as a fuel leak end up putting in a 383 at the same time. |
Posted on: 2012/2/12 16:30
BillH | Re: FUEL RETURN LINE | ||
Yea, good advice especially using a cutoff wheel. Your pics look good Marv. We had Kool-Tools in the race shop, makes installing the fittings a breeze but they cost a bunch. I've switched to the good, fabric covered push on hoses on the racecars mainly because I'm tired of bleeding. That's another reason to secure them like you suggested, if they flop around, you'll get one strand broken in the middle of a hose and bleed everytime you get your hand near it. I think your Summit parts are being shipped from here not AZ. I'm really lucky that I can walk in Summit's door and get parts (no shipping charges either). Attach file: summit.jpg (0.00 KB) |
Posted on: 2012/2/12 17:14
This is how we use to do it on the farm before they had cut off wheels. http://youtu.be/dkqO6wbKLZg. Sons gor a cut off saw and I have cut off wheels for my dermal tools and a big chissel. You were talking about using a 45 to hook into the fuel filter. Any adapters for the other line. Just picking your brain as you have been here before. Oh and any adapters needed to conect from the fittings to the old fule lines. Just to make my son happy we are going to the 4x4 shop monday to pick up parts for his rock crawler jeep. He said they have fittings there. So I will be calling on summit later Monday LoL. Steve |
Posted on: 2012/2/12 18:27
I keep forgetting... bastet44's 87 was such a pieced together pile of parts, that I forget it wasn't built to a standard...
Posted on: 2012/2/12 18:52
Like I said you need order 2 set of the nipple adapters 1 set go's on the fuel rail other set go's on the fuel filter O -Rings side go's into the fuel filter and fuel rail.
Now you can go with a straight type B nut fitting from the fuel filter area I would hook this side up first with either fitting you deside to use in this area installed to the hose you see the straight will work but a 45 degree type fitting will make a better transision up to the upper well wheel area. Also feed the hose from the top down makes life much easyer I did not cut the 10 foot hose I ordered yet I was just looped as 1 hose still, temp tie wrap the hose in to place to get your lengths right run the hose how you want it to the fuel rail fittings I used the 120 Dergee type tape and mark where you think it needs to be a couple extra inches of hose wont hurt any thing either just in case Murpheis Law LOL. Remove hose assy I put a extra tie wrap on either Press sure or return ONLY both ends so you can tell what, what just in case you need to remove the line latter to do some kind of other work to the fuel lines latter. Remove the lines cut and install upper fittings reinstall new fuel lines retie wrap the new fuel lines every couple inches for good and nut and bolt everything MAKE sure the fuel lines dont rub against the hot exhaust ect it could be a very bad thing if you dont do this. (I put some old rubber heater hose over the A/C hard lines ect just in case just to make sure the braided SS line dont saw it way though). Like I said the straight B nut fitting do work But I think 45 been better fit. You can cut the hose with the cave man Hammer and Chisel way of doing things but it seems you're have a better chance in fraying the steel braid wich will make it a nightmare to get the fittings on. I also didn't use the fancy blue wrench either LOL in the video. Quote:
Posted on: 2012/2/12 19:20
Edited by marv02 on 2012/2/12 20:06:04 |
Ok missed understood on the adapters. Two sets of these.
http://www.summitracing.com/parts/SUM-220009/ Better to ask questions instead of screwing up the job. Steve |
Posted on: 2012/2/12 19:37
Yep those are the puppies.
Posted on: 2012/2/12 19:57
If I was you ISTTER1 I would put a new Fuel fitler as long your under the care looks like the one in the pictures been there for a while.
Posted on: 2012/2/12 20:09
reading my mind Thanks Steve |
Posted on: 2012/2/12 20:24
Ordered parts (Funny Bill,Sparks NV) should be here this week. Next week is also a 3 day weekend for me. Teacher
Should have it done. Steve |
Posted on: 2012/2/12 23:59
Edited by istter1 on 2012/2/13 0:19:37 Edited by istter1 on 2012/2/13 0:30:54 |
O'Reilly's has Wix fuel filters for the C4. Very good filter.
Posted on: 2012/2/13 0:16
Funny Andy just got back from there they were on sale. Needed a 16mm line wrench. Steve |
Posted on: 2012/2/13 0:23
4 Day weekend for me then again it mite be a 3 day work week my kid sick I mite have to take tomarrow off from work to stay home with her.
Posted on: 2012/2/13 1:03
I was in there this week, picked up some roto-lok surface conditioning discs. Seems like I'm in there every other week for something. |
Posted on: 2012/2/13 1:07
Also I would start spraying the old fittings with some LIQUID WRENCH, WD40, something on the fitting now and the rest of the week It just might make you're job on breaking those tube fitting that much easyer.
Kinda like when I do transmission work I pull the pan a couple days early so it can drip it self dry so you dont have the ATF dripping on you face as you on you're back looking up at it Ya that sucks when that happens. |
Posted on: 2012/2/13 1:11
Marvin you are really funny. I left about 30 minutes ago to pick up some Liquid wrench. When I got back home my son had the hood up. He was trying to break the lines from the Fuel rail lose. One worked, He was getting ready to use vise grips on the other. No back up wrench on the rail nut. Nothing brocken yet. Lol Young ones hurry hurry . Sounds like parts are just around the corner for you Bill. Steve |
Posted on: 2012/2/13 1:51
Take the Vise grips and pliers away from you're Son LOL.
The precision Calibration Adjustment Tools Called a Big F-ing Hammer is my weapon of choice when everything else has faild LOL. Hey if you're know it screwed you cant make much worse why not. Quote:
Posted on: 2012/2/13 2:12
I wrapped the lines and sprayed them with PB Blaster while he watched me. He was going to use his propane plastic welder to warm up the lines.
There in these pictures of his last vehicle fire. Marvin he can do more damage. LOL Attach file: little fire problem.jpg (27.77 KB) final burn.jpg (3.83 KB) |
Posted on: 2012/2/13 3:10
Some duct tape bondo touch up paint and elbow grease the jeep will be good as new they make al kinds of aftermarket hop parts for them LOL.
Posted on: 2012/2/13 3:31
Now the vehicle are two different one. The second one he burned up by some mine that has been abonded for years. Out in the desert by you. They needed something to start a fire with . He unhooked his fule line over a hot vehicle cat. Boon
He has two more of those one I installed a new 4.0 in last summer. I have to keep buying tools as he has all of mine at his house. A father's love. Steve Attach file: ready tio pull.jpg (4.35 KB) |
Posted on: 2012/2/13 3:50
Worked like a charm. Marvin will the return line that is connected to the fuel rail connect to the SS line by the fuel filter using the fuel line end? It will be conecting to a Male end. Steve |
Posted on: 2012/2/15 1:39
Good deal glad it worked out for you.
Posted on: 2012/2/15 2:39
Parts should be here tomorrow. Hope to be over what ever crap I caught nose running sinus going crazy feel like head will . Will put it all together this 3 day weekend. knock on wood
Thanks for all the help. life goes on Steve |
Posted on: 2012/2/15 3:38
The addapter work on the fuel filter just like the ones on the fuel rail.
The end of the addapters go's in to the fuel rail same for the fuel filter and the return line fitting under the car next to the fuel filter it self. Did you go with the straight fitting at the fuel filter or the 45's. [/quote] Worked like a charm. Marvin will the return line that is connected to the fuel rail connect to the SS line by the fuel filter using the fuel line end? It will be conecting to a Male end. Steve[/quote] |
Posted on: 2012/2/15 13:43
Worked like a charm. Marvin will the return line that is connected to the fuel rail connect to the SS line by the fuel filter using the fuel line end? It will be conecting to a Male end. Steve[/quote][/quote] Will be using 45. The return line coming from the fule tank is a male fitting on the end.. From that fitting to the rail on the return line conection is a female. Will I need a a femal coupler to hook both males together ? The adapter I ordered are two sets male. |
Posted on: 2012/2/15 22:46
Edited by istter1 on 2012/2/15 23:43:15 Edited by istter1 on 2012/2/15 23:45:52 |
Summit was quick everything arrived. hoping for good weather this 3 day weekend.
steve |
Posted on: 2012/2/16 2:23
4 day weekend for me ya I rubbing it in LOL.
I will be working on my Vett also cutting off the old exhaust fixing the lock up convertor wire on the trans pulling the Govener out of the trans I changing the shift points so it shifts higher RPM's. Quote:
Posted on: 2012/2/16 4:32
Sounds like a lot of fun. 4 days LOL Steve |
Posted on: 2012/2/16 6:01
Nope a couple hours a day no hurry the Vett is my toy car I normaly drive the SUV during the weekend to haul the family around in.
And been driving to work during the week. I dont like Driving the Vett it in the Rain sometimes it get hairy when it wants to step out on you(He He Oh SH-T That was to close He He). I am also and bringing Boxes home from work we are having new home built and we are packing to move next Month. |
Posted on: 2012/2/16 13:46
I know in the rain they can spin on a dime. I love it. loved the soap pads we use to train on. It all changed when we got the front wheel jobs (SKUDS).
Son already been over ready to start. I told him no rush i like to do it in the day light. Do it right. I am lucky we aren't at his house he would have lost most of the parts already. These ADHD kids are very smart but hurry too much. Off to school soon . Steve |
Posted on: 2012/2/16 14:04
The world has come to an end !!! I was asking my son what size my return size fuel line was. thought 3/8. Need to pick up a JP hard line 3/8 to 6 an to connect return line to ss 6 an. He thought I needed my flaring tools. 90% of my hand tools are at his and his friends house. He is coming by tomorrow night to return almost all my hand tools. Not the cherry picker, transmission jack or the engine stand, air compresser and air tools, etc, but it is a hell of a start. steve He will more then likely bring back the sae mechanical ajuster. pipe wrench |
Posted on: 2012/2/17 4:19
Well any up dates.
Posted on: 2012/2/18 0:48
Question on this 3/8 nut and flare when you hook it to the line do you flare the line the silver fitting is flared??
Posted on: 2012/2/18 1:18
Put the B nut on first then the Sleave then Flare the line Is it single or double flair.
If you're were closer I just take to my work we have a machine that flairs. We do this kind of work at least once week Aircraft lines alway going bad. |
Posted on: 2012/2/18 1:43
it is a single flare only goes on one way. Seamed funny to put a flare on a flare have all the tools.
thanks Steve |
Posted on: 2012/2/18 2:02
Dont Laugh we make line with lot bends from blueprints you have make sure is right ect to make sure the line in specs cut it to lenght flair the ends then find out you forgot to put the fitting on before you flaired it man that ruins your day LOL.
Posted on: 2012/2/18 2:08
As long as it works
When son gets here we will get her done. Daughter in law here with the girls eating me out of food. LOL Love them Steve |
Posted on: 2012/2/18 2:14
