85vet | Is the water heater shut off valve required? | ||
Noticed a slight anti-freeze leak and finally found it. The water shut off valve for the heater is leaking. it is part of the solid tubing section of the heater/water lines in the engine compartment and has a vacuum line going to it.
I see that these were only installed on 85 through 87 so I am wondering if it can be completely bypassed and eliminated. I would appreciate your comments. Thanks, Jim |
Posted on: 2008/2/9 18:13
85-Z51 4+3 - Now 700r4 427, TPIS Solid Roller700/701-ported AFR 220, Rossler700r4, 4,000 stall (Engine by CORKVETTE1), 3.54 gears |
bogus | RE:Is the water heater shut off valve required? | ||
bypass it as in bypass the heater? or just run straight to the heater core?
There is a steam vent off the back of the engine that attaches to the valve rig you refer too... I donno what that will do in the long run. |
Posted on: 2008/2/9 18:38
MK 82 | RE:Is the water heater shut off valve required? | ||
You can take it out and replace with heater hose. A manual shutoff valve would be a good idea.
Posted on: 2008/2/9 18:42
96 CE Roadster LT4 |
85vet | RE:Is the water heater shut off valve required? | ||
bypass it as in bypass the heater? or just run straight to the heater core? Interesting, I only see a vacuum line that attaches to the valve. I want to eliminate the hard lines that the bypass valve is part of and run heater hoses directly to the heater core. If our systems are closed where would steam come from? Sorry if this might be a stupid question. Thanks, Jim |
Posted on: 2008/2/9 19:52
You can take it out and replace with heater hose. A manual shutoff valve would be a good idea. Not sure why I need a shut-off valve, the current valve had no effect when my heater core died, it leaked inside the car. I bypassed the heater completely until I replaced the heater core. |
Posted on: 2008/2/9 19:55
Agent86 | RE:Is the water heater shut off valve required? | ||
Not needed as proven by later C4's that didn't get the valve. Mine leaked too, so I cut the bitch out.
Posted on: 2008/2/9 20:16
Thanks Agent 86 - that's what I wanted to see.
Posted on: 2008/2/9 21:18
Quote: Two reasons. 1. Without the valve, water will flow through the heater core at all time. If your ducts are tight and all the doors works OK it is not a problem 2. If the heater puts out hot air when you don't want it or you develop the dreaded core leak you can shut it off. |
Posted on: 2008/2/9 21:42
CasetheCorvetteman | RE:Is the water heater shut off valve required? | ||
DropTopCE, the coolant does run through the heater core all the time on 92 and up. No good reason not to.
With the coolant running through the core all the time and not sitting still for months, youre not having coolant go stagnant in the core, and as long as youre looking after youre cooling system, the heater core should last longer with coolant flowing full time. |
Posted on: 2008/2/9 22:41
DropTopCE, the coolant does run through the heater core all the time on 92 and up. No good reason not to. Good, then he can leave it open till something goes wrong. Entirely optional but I would do it. Maybe I am the paranoid type. YMMV. |
Posted on: 2008/2/9 22:46
Touringmike | RE:Is the water heater shut off valve required? | ||
You can take it out and replace with heater hose. A manual shutoff valve would be a good idea. Well, I replaced my steel tubes with 3/4 and 5/8 hoses (I think, it was 6 years ago). If the heater core ever leaks, I'll just remove the hoses from the core and butt them together. I never use the heater anyway (car's in storage for the winter months) |
Posted on: 2008/2/9 22:48
ยด85 4+3 |
Good, then he can leave it open till something goes wrong. Entirely optional but I would do it. Maybe I am the paranoid type. YMMV. If something goes wrong, closing the tap wont stop the core from leaking, the coolant can still go in from the other end. |
Posted on: 2008/2/10 3:06
CFI-EFI | RE:Is the water heater shut off valve required? | ||
My car had the water shutoff valve bypassed and removed over 21 years ago. There have been no adverse effects.
RACE ON!!! |
Posted on: 2008/2/10 23:45
Thanks for all the input. I don't think I need it, but I will check to see if I can buy it used for reasonable $'s, otherwise it is GONE.
Posted on: 2008/2/11 3:38
