jmartynuska | Front Spring Seat Lube | ||
I'm getting ready to swap out the front spring. What, if anything, should I use to lube the a-arm seat, or should I just make sure it's really clean?
Any other tips/hint/suggestions would be appreciated as well. TIA... Jeff |
Posted on: 2012/2/28 19:48
'89 Z51/'02 Z06 45/145BS NER SCCA |
1Fast04Vert | Re: Front Spring Seat Lube | ||
Just clean, no lube.
Posted on: 2012/2/28 21:40
BillH | Re: Front Spring Seat Lube | ||
Yep. If you lube it - the lube gets dirty- dirty lube acts like a grinding paste. |
Posted on: 2012/2/29 0:17
jmartynuska | Re: Front Spring Seat Lube | ||
Just cleaning it will be then.
Thank you for the replies! |
Posted on: 2012/2/29 17:11
