65 user(s) are online (42 user(s) are browsing Forums)
jmartynuska Front Spring Seat Lube
Rindge, NH
51 Posts
I'm getting ready to swap out the front spring. What, if anything, should I use to lube the a-arm seat, or should I just make sure it's really clean?
Any other tips/hint/suggestions would be appreciated as well.
TIA...
Jeff
Posted on: 2012/2/28 19:48
'89 Z51/'02 Z06
45/145BS NER SCCA
1Fast04Vert Re: Front Spring Seat Lube
Just clean, no lube.
Posted on: 2012/2/28 21:40
BillH Re: Front Spring Seat Lube
Yep.
If you lube it - the lube gets dirty- dirty lube acts like a grinding paste.
Posted on: 2012/2/29 0:17
jmartynuska Re: Front Spring Seat Lube
Rindge, NH
51 Posts
Just cleaning it will be then.
Thank you for the replies!
Posted on: 2012/2/29 17:11
'89 Z51/'02 Z06
45/145BS NER SCCA
