132 user(s) are online (112 user(s) are browsing Forums)
vis_croceus Front/rear stagger and later ABS/ASR
VA
260 Posts
Anybody got first hand experience with stagger in the 5-6% range?
I'm looking at a tire size that will give me ~ 5.7% stagger.
My own experience is that 4% works fine and 8% pisses off the computer.
I've seen some posts on CF that say the limit is 5%, but it's unclear whether the poster actually has experience or just heard that somewhere...
Posted on: 2012/4/15 5:07
94 vert
Jagdpanzer Re: Front/rear stagger and later ABS/ASR
Northern VA
12 Posts
I recently went to staggered front and rear tire sizes ,5%, on my 94. After a few miles the check ABS and ASR lights would always come on. Changing the the ABS speed pickup reluctor wheels on the rear spindles from 47 to 50 teeth solved the problem.
Posted on: 2012/4/15 20:12
Matatk Re: Front/rear stagger and later ABS/ASR
Good info, Phil. And beautiful car, too!
Posted on: 2012/4/15 21:59
bogus Re: Front/rear stagger and later ABS/ASR
Very interesting stuff. I had no idea you could change the relutor wheel like that.
That is about a 6% change, so the 5% change in wheel then means a 1% change by the computer, all is great!
Posted on: 2012/4/15 23:47
vis_croceus Re: Front/rear stagger and later ABS/ASR
VA
260 Posts
Changing reluctor rings had not occurred to me.
I assume you had that made custom?
Nice car and wheels!
Posted on: 2012/4/16 3:57
94 vert
Northern VA
12 Posts
Thanks for the compliments guys.
Yes, machined out of 416 stainless steel
Posted on: 2012/4/18 23:40
VA
260 Posts
Revisiting this - I have a few hundred miles now with ~6.5% larger in rear. No problems.
Posted on: 2012/10/6 6:26
94 vert
Glad it's working out.
There are a ton of people doing wheel/tire swaps out there and Phil's example of having to change the ABS reluctor ring is the first I've heard of it.
Posted on: 2012/10/6 11:36
I wonder if some years computer is more picky than others?
Posted on: 2012/10/6 15:04
