287 user(s) are online (237 user(s) are browsing Forums)
TommyT-Bone Art has a question. 76 Corvette headlights.
Hi. my name is Art. I live in a suburb of Alb,nm. I own 5 classic cars and my overall best is a red 76 stingray. she has a 383 with a tunnel ram, m22 trans, 413 rear gears, nitrous and the body and interior are stock with the exception of a tail from an 81 corvette. i just like the spoiler. my problem is the engine is built and with the cam i have ( 632 lift ) i have virtually no vacuum, so i am using a exhaust evacuation system and no power brakes. i am looking for an alternative to the vacuum headlights.
Posted on: 2012/6/12 3:33
Durango_Boy Re: Art has a question. 76 Corvette headlights.
I have two solutions for two issues it seems the poster is having.
Headlights - The cheapest way is to separate the headlight vacuum system from the engine. You can keep the connection to the switch and override but instead of sourcing from the engine, use a small vacuum pump to pull from the tank as the source. I've been trying to design something like this on the side for a while. I was thinking of a small 12V vacuum pump and some kind of backwards pressure switch that gets the tank to 12 - 15 Hg and then cuts power...like the switches on air compressors...just backwards.
My thinking is that the pump could be triggered by a relay that comes on with the IGN. Then, the pump only runs until the vacuum in the tank gets above 15 Hg then the switch would cut the ground from the relay so the pump is not running all the time. Then say you use the headlights...the vacuum drops below 12 Hg, and the switch provides ground to the relay, and the pump kicks back on until it's above 15 Hg again.
I just never got far enough to find a switch like that. The pump itself would not need to be expensive since it wouldn't run all the time. The pricey pumps are usually on all the time to compensate for low vacuum engines that cater to things like brakes and vacuum advance distributors.
Now, on to safety...
Brakes - Can you explain a little bit about the statement, "no power brakes"? Does this mean you have converted to manual brakes and can safely stop the car, or are you just pressing as hard as you can on a power brake car with no vacuum in order to stop?
My solution to poor vacuum braking has been a Hydrobooster. I've been putting them in C3s for years now and it's by far the best solution I have ever found.
Essentially, it's a hydraulic power assist unit that uses power steering pressure to assist the brakes instead of engine vacuum. I can help with everything from the unit itself, to the parts to order to make the pressure lines, and step by step installation help through the whole process. All I need is an email address and I have an information file I can send that has pictures and text explaining what it is and how it works to correct bad brakes because of low vacuum.
Posted on: 2012/6/12 12:01
TommyT-Bone Re: Art has a question. 76 Corvette headlights.
ttt
Posted on: 2012/6/13 23:38
nmbadboy Re: Art has a question. 76 Corvette headlights.
southwest us
6 Posts
my answer is yes to both questions. i converted to manual brakes ( no power assist ) and yes you have to put your foot thu the floor at real high speeds. i tried a hydro boost but im turning some pretty high RPM's, at times and when i do i launch the power steering belt. actually i used to launch all the belts. as far as water pump and alternator im using a gilmer set up. and no power steering either.
Posted on: 2012/6/13 23:54
Matatk Re: Art has a question. 76 Corvette headlights.
Art -
Pardon my ignorance, but what do you mean by an exhaust evacuation system?
Have you considered an external vacuum reserve canister such as this:
http://www.jegs.com/InstallationInstr ... s/200/270/270-99590-1.pdf
Or perhaps a vacuum pump?
I personally have zero experience with either, I just know I've read about them in the past.
Also, are you brake components up to par? Have you done any changes to the braking system? I know the brakes on my dad's 79 seem adequate, but are far from superior.
Posted on: 2012/6/14 2:11
southwest us
6 Posts
Mat I have a system where a fluted 1/2" steel pipe is welded into each header collector at a 45 deg angle. and threaded to it is a one way valve connected to a 5/8 heater hose connected to a oil separator into valve covers. which seem to work pretty well. my set up is made by moroso, there is also a non fluted one made by mr gasket and there are numerous ones on ebay
Posted on: 2012/6/14 3:51
southwest us
6 Posts
Matt sorry i guess the correct terminology would be crankcase evacuation system
Posted on: 2012/6/14 3:55
