232 user(s) are online (188 user(s) are browsing Forums)
BillH Time Trials Pics
I was out in the fast shit today.
The Porsche GT3 RS is just a phenomenal (hell, it outa be for $250k). 500 horse, carbonfiber brake rotors, very special suspension.
And the Toyota MR2, upgraged suspension, big brakes and a slight turbo upgrade , the stock turbo is set at about 5 psi., this turbo is bigger and set at 18 psi
jpg  2006-02-15 21-57-07_0002.JPG (0.00 KB)
jpg  2006-02-15 21-57-25_0003.JPG (0.00 KB)
jpg  2006-02-15 21-57-35_0004.JPG (0.00 KB)
jpg  2006-02-15 21-57-47_0005.JPG (0.00 KB)
jpg  2006-02-15 22-09-19_0009.JPG (0.00 KB)
jpg  2006-02-15 22-08-43_0007.JPG (0.00 KB)
jpg  2006-02-15 22-09-32_0010.JPG (0.00 KB)
Posted on: 2012/7/1 23:08
BillH Re: Time Trials Pics
My buddie broght his Jag back to play.
Also had 8 Corvettes.
Posted on: 2012/7/1 23:09
Ultraman Re: Time Trials Pics
14760 Posts
Does the guy who owns the Porshaa drive it on the street or is it just for track time.....? Geez that's two brand new ZR1's sitting there.....
Posted on: 2012/7/1 23:25
Note in the rear pic, license plate area, there's a tow hook and the red square thing is a timing & scoring transponder.
Um, er, ah----Pete has 5 outer Porsche's and a couple of them are as prick as this one, one is full race, cage etc.
and 4 for the street I guess.
BTW, after I rode with him, his lap times came dow by 2 seconds which is a lot since he was already fast.
Posted on: 2012/7/1 23:30
14760 Posts
Ahh....he's lucky to have a such a good job......
Posted on: 2012/7/1 23:36
Yea...........there's always a couple guys at the track who have big bucks.
I AIN'T ONE ON EM.
The guy with the Jag has 2 Lamborghinis to play with on the street.
Posted on: 2012/7/2 0:01
Matatk Re: Time Trials Pics
How is the toyota compared to the porsche?
Posted on: 2012/7/2 2:05
Not much comparison, the Toyo is stiff sprung, handles decent, is fast (running similar lap times to a prepped Z06, both drivers are reasonably fast).
But the Porsche will run away from both with a good driver.
Very comfortable car, handles like a gokart, very flat in the corners (though the high G forces beat you up).
The best part of the car is probably the brakes, just can't describe how good they are. They will leave marks on your shoulders from the belts. You can brake from 120 mph 50 to 75 feet later going into a corner than you can with a C6.
The only car that could run with this car would be a ZR1.
Posted on: 2012/7/2 13:19
I figured the Porsche would walk all over the Toyota. But it still sounds impressive, although this is clearly a purpose built car with some thought in it. I'm sure the same mods in a Z06 would be astonishing.
Posted on: 2012/7/2 19:24
Well, there are NO mods on this car. Straight from the factory this way.
Posted on: 2012/7/2 20:18
No mods to the Porsche, right?
My fault, I was not clear in my post and I was referring to the Toyota...ie, bigger turbo, etc.
Posted on: 2012/7/2 21:57
Ah, OK. The Toyo is running against a modded Z, gutted interior, cage, coilovers, laydown radiator, more horse than a stock Z.
The driver of the Z is reasonably fast but I've never ridden with him.
The only real way to compare is if I did some laps in both and that probably won't happen.
The Toyo does have a huge weight advantage.
Posted on: 2012/7/2 23:14
