336 user(s) are online (281 user(s) are browsing Forums)
Antilock Braking System.
VetteUSA Full Write-up on C4 Window Alignment
103 Posts
Hey all. I haven't been around on C4Guru for a while. Here is a write-up I did on fixing window alignment problems that some of us have. The main symptom of the alignment problem is when the corner of the window scrapes or hits the side pillar as you close your door. The likely problem is a broken window stop guide.
http://www.savefile.com/files/1021776
Posted on: 2008/2/18 2:37
Oaklands RE:Full Write-up on C4 Window Alignment
Morristown, TN
480 Posts
Good info. Thanks for taking the time to document it.
Posted on: 2008/2/19 0:33
skirlin RE:Full Write-up on C4 Window Alignment
Caledonia Michigan
277 Posts
When I hit the link I get an add for a free Super Mario Galaxy thing. How do I get around it?
Posted on: 2008/2/19 6:15
VetteUSA RE:Full Write-up on C4 Window Alignment
103 Posts
I'm not sure what you're talking about, so I've uploaded to an additional location.
http://usacorvette.tripod.com/_privat ... indowAlignmentWriteUp.pdf
Posted on: 2008/2/19 20:47
