VetteUSA | Full Write-up on C4 Window Alignment | ||
Hey all. I haven't been around on C4Guru for a while. Here is a write-up I did on fixing window alignment problems that some of us have. The main symptom of the alignment problem is when the corner of the window scrapes or hits the side pillar as you close your door. The likely problem is a broken window stop guide.
http://www.savefile.com/files/1021776 |
Posted on: 2008/2/18 2:37
Oaklands | RE:Full Write-up on C4 Window Alignment | ||
Good info. Thanks for taking the time to document it.
Posted on: 2008/2/19 0:33
If duct tape or baling wire won't work, it can't be fixed! |
skirlin | RE:Full Write-up on C4 Window Alignment | ||
When I hit the link I get an add for a free Super Mario Galaxy thing. How do I get around it?
Posted on: 2008/2/19 6:15
There is no point in living if you can't feel alive. |
VetteUSA | RE:Full Write-up on C4 Window Alignment | ||
When I hit the link I get an add for a free Super Mario Galaxy thing. How do I get around it? I'm not sure what you're talking about, so I've uploaded to an additional location. http://usacorvette.tripod.com/_privat ... indowAlignmentWriteUp.pdf |
Posted on: 2008/2/19 20:47
