217 user(s) are online (166 user(s) are browsing Forums)
Ramrod Tow Points?
S. California
296 Posts
Where the heck are you hooking up for tow points when you run on a track? Can you figure out something that would come out of the front and rear license plates?
Posted on: 2008/2/18 15:31
bogus RE:Tow Points?
Posted on: 2008/2/18 15:37
pappyfreebird RE:Tow Points?
1028 Posts
thats a great tip thanks anybody happin ta know where they be on a 95 fbody trans am???
Posted on: 2008/2/18 17:33
Ramrod RE:Tow Points?
S. California
296 Posts
I tried the tech section, and all I got was "this site blah blah blah" computer stuff, must be something to do with the words "Jacking Point" that stop the search. I'll check my owners manual. Thanks
Posted on: 2008/2/20 3:13
FLYINLOW90 RE:Tow Points?
Windsor Ontario Canada
514 Posts
Not a good day!!!!!!!!!
Posted on: 2008/2/20 3:19
1028 Posts
hey dude ifn i can do it you can do it....jus hit tech library then click on chassis .... noice articals n easy ta use
Posted on: 2008/2/20 13:41
S. California
296 Posts
I think it's on my end Pappy
Posted on: 2008/2/22 1:08
SpectatorRacing RE:Tow Points?
There are a lot of ways to do this...
Most weld or bolt a solid tow loop to the front and rear bumper structure. You need to cut a hole somewhere on your bumper for this.
You can also take a piece of steel cable, wrap it around the structure, and poke it through somewhere (like the front marker lights or the license plate). Just make sure it's lined up right or when you pull on it you'll rip the bumper off...
I can take pictures of the race car later but can't do photobucket from work...
Posted on: 2008/2/22 15:25
