woody3882 | Newbie Questions.. | ||
Thanks to all for help in the past, it is appreciated,
I am new at this and yes I have purchased every manual I find for my 1994 c-4 LT-1. I do have three questions that I am sure are easy for the pro's 1, My engine block number is V0924WHF My VIN number is 1G1YY22P2R5107979 I see no similiarites in the numbers, is the engine number supposed to be patially included in the VIN or this motor a past donor. 2, The transmission has a red casing, is that an original for the 94 LT1 or is that also a donor over the years 3, I have repeatedly tried to program the new remote for the passive door lock (PKE). I have read a hundred articles on how to do it, but something isn't working right. I know the system is acknowledging the remote because the Passive Keyless Entry lamp comes on when the remote is in range, but when I try to program the car. After I push the trip odometer once, then the second time, then when I push the Trip Fuel Information button for ten plus seconds, the Passive Keyless Entry lamp NEVER illuminates constantly indicating it is in the programming mode I know this subject has been beaten to death, but I hate to install an after market passive locking system, I was just hoping someone else has overcome the same situation. Below is the instructions I have been trying to program the system. Thanks again to all for your help. I just hope that some day I can pay-it-forward. Woody PKE programing instructions 1. Move the transmitters to be programmed 12 to 15 feet away from the car. 2. Turn the ignition to the Run position, engine off. 3. Push the Trip Odometer button once and release (Image B). 4. Push the Trip Odometer button again and hold for five seconds. 5. Within five seconds push and hold the Fuel Information button for 10 seconds, until the Passive Keyless Entry lamp illuminates constantly (Image C). 6. Turn the key to the locked position with the key remaining in the ignition. The Passive Keyless Entry lamp should flash once per second, signaling that the system is ready to program the first transmitter. The number of times the light flashes corresponds to the number of the transmitter you're programming—once per second for the first transmitter, twice per second for the second, and three times per second for the third. 7. Bring the transmitter to be programmed into range. 8. The Passive Keyless Entry light will come on and stay on, signaling that the code has been stored. 9. Move the transmitter out of range. The system light will flash again, demonstrating that the system is ready for the next transmitter. 10. The programming mode can be exited by removing the key from the ignition or by turning the ignition on. Attach file: pic vette 12-11-12.jpg (47.98 KB) |
Posted on: 2013/1/18 20:07
bogus | Re: Newbie Questions.. | ||
nice looking car!!! Very cool!!!!!
Hm... red cased transmission? they came in natural metal colour from the factory. I wonder if it was powder coated or something. The big difference is the colour of the tag on the transmission. If this was a manual, it would be blue; earlier were black. The black tagged 6spds were made in West Germany, the blue tags in Alabama. As for the engine/vin... I encountered the same thing. I expected a 2nd set of numbers just off the right side block deck... nada... now, there is a place on the side of the block near the oil filter... check there, if you can. Can't help with PKE... it's a fussy little beotch. |
Posted on: 2013/1/18 22:56
BillH | Re: Newbie Questions.. | ||
Yea, nice car.
You can do a disgnostic check by jumping pins 4 & 8 on the ADL connector. The pinout on the TOP row is; 1 2 3 4 5 6 7 8 And the PKE diagnostic system works as follows: With pins 4 and 8 connected, the PKE light in the Driver Info Centre will flash the codes. Here is the list of DTCs and what they mean: DTC #12: Receiver Memory Bad DTC #13: Transmitter Not in Range DTC #14: Non-Valid Transmitter Received DTC #15: Valid Transmitter Received DTC #16: Passenger Door Button Depressed DTC #17: Hatch Button Depressed Good Luck BTW, If you don't have a Factory Service Manual - get one. It's impossible to work on your car without one. |
Posted on: 2013/1/19 0:38
Matatk | Re: Newbie Questions.. | ||
As far as engine ID, I think this applies to vettes as well as camaros.
http://shbox.com/1/block_vin.jpg |
Posted on: 2013/1/19 1:55
vetteoz | Re: Newbie Questions.. | ||
I have worked on three (92/94/96 ) original Vette LT1 engines. They have all had the traditional 3 digit SBC engine suffix stamped on the front block pad. All Vette LT1's had a code beginning with Z ;for '94 ZWA; LT1 w/auto ZWB: LT1 w/ man so I suspect with WHF your Vette is not a virgin V0924 is the production plant / date code Quote:
This Caprice iron head LT1 doesn't appear to have the partial Vin stamped so maybe GM stopped doing that when they started stamping the rear of the block as shown above ? |
Posted on: 2013/1/19 4:31
Found it
WHF ; '94 Impala .275Hp .Auto .Ca emissions Your engine doesn't have cast iron heads does it? |
Posted on: 2013/1/19 4:38
woody3882 | Re: Newbie Questions.. | ||
I will check the heads today, but I did find this code information that I hope someone else might need. Now all I need is to find out where the red transmission came from.
take care Woody Code Year CID HP BBL Appl UA 1969 307 200 2 M/t UAA 1981 305 140 2 conv. cab, m/t UAB 1981 305 140 2 conv. cab, a/t UAC 1981 305 140 2 conv. cab, m/t UAD 1981 305 140 2 conv. cab, a/t UAF 1981 305 140 2 van & bus, m/t UAH 1981 305 140 2 van & bus, a/t UAJ 1981 305 140 2 conv. cab, m/t UAK 1981 305 140 2 conv. cab, a/t UAT 1981 305 150 4 con. cab, m/t, A.I.R. UAU 1981 305 150 4 con. cab, m/t, A.I.R. UAW 1981 305 150 4 con. cab, a/t, A.I.R. UAX 1981 305 150 4 van & bus, m/t UAY 1981 305 150 4 van & bus, a/t UAZ 1981 305 140 2 conv. cab, A.I.R. UB 1969 307 200 2 m/t UBA 1983 305 145 4 van, bus, a/t, Cal UBB 1983 305 145 4 con. cab, m/t, A.I.R. UBC 1983 305 145 4 con. cab, a/t, A.I.R. UBD 1983 305 145 4 con. cab, a/t, A.I.R. UC 1969 307 200 2 Powerglide UCA 1983 305 150 4 conv.cab UCB 1983 305 150 4 conv.cab UCC 1983 305 150 4 conv.cab UCD 1983 305 150 4 conv.cab UCF 1983 305 150 4 conv.cab UCH 1983 305 150 4 conv.cab UCJ 1983 305 150 4 conv.cab UCK 1983 305 150 4 conv.cab UCM 1983 305 150 4 conv.cab UCN 1983 305 150 4 conv.cab UCR 1983 305 150 4 conv.cab UCT 1983 305 150 4 conv.cab UCU 1983 305 150 4 conv.cab UD 1969 307 200 2 Powerglide, A.I.R. UDA 1983 305 150 4 conv.cab UDB 1983 305 150 4 conv.cab UDC 1983 305 150 4 conv.cab UDD 1983 305 150 4 conv.cab UDF 1983 305 150 4 conv.cab UDH 1983 305 150 4 conv.cab UDJ 1983 305 150 4 conv.cab UDK 1983 305 150 4 conv.cab UDM 1983 305 150 4 conv.cab UDN 1983 305 150 4 conv.cab UDR 1983 305 150 4 conv.cab UDS 1983 305 150 4 conv.cab UDT 1983 305 150 4 conv.cab UDU 1983 305 150 4 conv.cab UE 1969 307 200 2 tur hydro, A.I.R. UF 1969 307 200 2 tur hydro UFA 1980 350 165 4 van, bus, a/t, Cal UFB 1980 350 165 4 van, bus, m/t, Cal UFC 1980 350 165 4 van, bus, a/t, Cal UFD 1980 350 165 4 van, bus, m/t, Cal UFF 1980 350 165 4 van, bus, a/t, Cal UFH 1980 350 165 4 van, bus, m/t, Cal UFJ 1980 350 165 4 fwrd cab, a/t UFK 1980 350 165 4 fwrd cab, a/t UFR 1980 350 165 4 fwrd cab, a/t, Cal UFS 1980 350 165 4 fwrd cab, a/t UFT 1980 350 150 2 conv. cab, m/t UFU 1980 350 150 2 conv. cab, a/t UG 1969 307 200 2 - UH 1969 307 200 2 - UHA 1981 350 165 4 con. cab, m/t, A.I.R. UHB 1981 350 165 4 con. cab, a/t, A.I.R. UHC 1981 350 165 4 con. cab, m/t, A.I.R. UHD 1981 350 165 4 con. cab, a/t, A.I.R. UHF 1981 350 165 4 van & bus, m/t UHH 1981 350 165 4 van & bus, m/t UHJ 1981 350 165 4 van & bus, a/t UHK 1981 350 165 4 con, a/t, A.I.R., Cal UHL 1981 350 165 4 con. cab, A.I.R., Cal UHM 1981 350 165 4 con, a/t, A.I.R., Cal UHR 1981 350 165 4 conv. cab, A.I.R. UHS 1981 350 165 4 con, a/t, A.I.R., Cal UHT 1981 350 165 4 van, bus, a/t, Cal UHU 1981 350 165 4 van, bus, a/t, Cal UHW 1981 350 165 4 con cab, m/t, A.I.R. UHX 1981 350 165 4 con cab, a/t, A.I.R. UHY 1981 350 165 4 con, m/t, A.I.R., Cal UHZ 1981 350 165 4 con, a/t, A.I.R., Cal UI 1969 307 200 2 - UJ 1969 307 200 2 - UJA 1981 350 165 4 van & bus, m/t UJB 1981 350 165 4 van & bus, a/t UJC 1981 350 165 4 van, bus, m/t, Cal UJD 1981 350 165 4 van, bus, a/t, Cal UJF 1981 350 165 4 fwrd cab, m/t UJH 1981 350 165 4 fwrd cab, a/t UJJ 1981 350 165 4 fd cab, m/t, Calif UJK 1981 350 165 4 fd cab, a/t, Calif UJL 1981 350 165 4 fwrd cab, m/t UJM 1981 350 165 4 fwrd cab, a/t UJR 1981 350 165 4 fd cab, m/t, Calif UJS 1981 350 165 4 fd cab, a/t, Calif UJT 1981 350 165 4 fwrd cab, m/t UJU 1981 350 165 4 con. cab, m/t, A.I.R. UJW 1981 350 165 4 con. cab, a/t, A.I.R. UK 1969 307 200 2 UKA 1981 350 150 2 con. cab, m/t, A.I.R. UKB 1981 350 150 2 con cab, a/t, A.I.R. UL 1969 307 200 2 UM 1969 307 200 2 tur hydro UN 1969 307 200 2 - UO 1969 307 200 4 M/t UP 1969 307 200 2 M/t UQ 1969 307 200 4 tur hydro URA 1983 350 165 4 conv.cab URB 1983 350 165 4 conv.cab URC 1983 350 165 4 conv.cab URD 1983 350 165 4 conv.cab URF 1983 350 165 4 conv.cab URH 1983 350 165 4 conv.cab URJ 1983 350 165 4 conv.cab URK 1983 350 165 4 conv.cab URM 1983 350 165 4 conv.cab URN 1983 350 165 4 conv.cab US 1979 305 160 4 LG4 USA 1983 350 165 4 conv.cab USB 1983 350 165 4 conv.cab USC 1983 350 165 4 conv.cab USD 1983 350 165 4 conv.cab USF 1983 350 165 4 conv.cab USH 1983 350 165 4 conv.cab USJ 1983 350 165 4 conv.cab USK 1983 350 165 4 conv.cab USM 1983 350 165 4 conv.cab USN 1983 350 165 4 conv.cab USR 1983 350 165 4 conv.cab USS 1983 350 165 4 conv.cab UST 1983 350 165 4 conv.cab USU 1983 350 165 4 conv.cab USW 1983 350 165 4 conv.cab USX 1983 350 165 4 conv.cab USY 1983 350 165 4 conv.cab USZ 1983 350 165 4 conv.cab UT 1979 305 160 4 LG4 UT 1969 307 200 4 M/t UTA 1977 305 145 2 conv. cab, m/t UTB 1977 305 145 2 conv. cab, a/t UTC 1977 305 145 2 van & bus, m/t UTD 1977 305 145 2 van & bus, a/t UTF 1977 305 145 2 conv. cab, m/t UTH 1977 305 145 2 conv. cab, a/t UTJ 1980 305 145 2 conv. cab, m/t UTL 1980 305 145 2 conv. cab, a/t UTR 1978 305 145 2 conv.cab UTS 1978 305 145 2 conv.cab UTT 1978 305 145 2 van & bus UTU 1978 305 145 2 van & bus UTW 1978 305 145 2 conv.cab UTX 1978 305 145 2 conv.cab UU 1969 307 200 2 m/t UUB 1983 350 165 4 conv.cab UUC 1983 350 165 4 conv.cab UUD 1983 350 165 4 conv.cab UUF 1983 350 165 4 conv.cab UUH 1983 350 165 4 conv.cab UUJ 1983 350 165 4 conv.cab UV 1969 307 200 2 m/t UW 1969 307 200 2 m/t UYR 1979 305 145 2 conv. cab, m/t UYS 1979 305 145 2 conv. cab, a/t UZA 1981 350 165 4 con cab, m/t, exp UZB 1981 350 165 4 con cab, a/t, exp UZC 1981 350 165 4 con cab, m/t, exp UZD 1981 350 165 4 con cab, a/t, exp VB 1969 350 255 4 m/t VJZ 1972 350 175 4 m/t VR 1969 350 255 4 m/t, 3 spd VS 1969 350 255 4 m/t, 3 spd WA 1965 283 175 2 M/t WA 1968 307 200 2 M/t WA 1969 350 255 4 - WB 1967 283 175 2 m/t WB 1968 307 200 2 M/t WC 1967 283 175 2 tur hydro WC 1968 307 200 2 m/t, 3 spd WCB 1994 350 275 TPI F, Manual, early WCC 1994 350 275 TPI F, Auto, early WD 1967 283 175 2 - WD 1968 307 200 2 - WE 1965 283 175 2 M/t WE 1968 307 200 2 Powerglide WF 1966 283 175 2 m/t, A.I.R. WF 1968 307 200 2 M/t WF 1969 350 215 2 - WG 1967 283 175 2 m/t WG 1968 307 200 2 m/t WH 1966 283 175 2 Powerglide, A.I.R. WH 1968 307 200 2 m/t WH 1969 350 255 4 m/t, A.I.R. WHA 2000 346 305 TPI F, Auto, 320hp on SS WHB 2000 346 305 TPI F, Manual, 320hp on SS WHD 1994 350 275 TPI F, Manual, Oil Cooler, early WHF 1994 350 275 TPI F, Auto, Oil Cooler, early WI 1967 283 175 2 m/t WI 1968 307 200 2 M/t WI 1969 350 255 4 - WJ 1969 350 255 4 Powerglide WK 1969 350 255 4 tur hydro WL 1967 283 175 2 - WL 1968 307 200 2 - WL 1969 350 255 4 Powerglide, A.I.R. WM 1967 283 175 2 - WM 1968 307 175 2 - WM 1969 350 255 4 - WN 1968 307 200 2 - WN 1969 350 255 4 m/t, A.I.R. WO 1967 283 175 2 m/t WO 1968 307 200 2 m/t, 3 spd WO 1969 350 255 4 m/t WP 1968 307 200 2 - WP 1969 350 255 4 tur hydro WQ 1968 307 200 2 - WQ 1969 350 255 4 turbohydro, A.I.R. WR 1967 283 175 2 turbohydro, A.I.R. WR 1968 307 200 2 m/t, 3 spd WR 1969 350 255 4 Powerglide WS 1969 350 255 4 turbohydro WT 1969 350 255 4 M/t WTA 1994 350 275 TPI F, Manual, Oil Cooler WTB 1994 350 275 TPI F, Auto, Oil Cooler WTC 1994 350 275 TPI F, Manual WTD 1994 350 275 TPI F, Auto WW 1967 283 175 2 - WW 1968 307 200 2 - WZ 1969 350 255 4 m/t, 3 spd XA 1969 350 255 4 m/t XB 1969 350 255 4 M/t XC 1969 350 255 4 Powerglide XD 1969 350 255 4 turhydro XE 1963 327 - universal service XE 1969 350 255 4 M/t XF 1969 350 255 4 Powerglide XG 1969 350 255 4 turbohydro XH 1969 350 215 2 - XHN 1995 350 275 TPI F, Auto, Oil Cooler, early XHP 1995 350 275 TPI F, Manual, Oil Cooler, early XHW 1995 350 275 TPI F, Manual, early XHY 1995 350 275 TPI F, Auto, early XI 1969 350 215 2 - XJ 1969 350 215 2 - XK 1969 350 215 2 - XN 1969 350 215 2 - XO 1969 350 255 4 turbohydro, A.I.R. XP 1969 350 255 4 m/t, A.I.R. XPF 1995 350 275 TPI F, Auto, Oil Cooler XPK 1995 350 275 TPI F, Manual, Oil Cooler XPL 1995 350 275 TPI F, Manual XPN 1995 350 275 TPI F, Auto XPS 1995 350 275 TPI F, Auto, CA Emmissions XS 1969 350 215 2 - XTA 1995 350 275 TPI F, Manual, CA Emmissions, early XU 1969 350 215 2 - XV 1969 350 215 2 - XW 1969 350 255 4 m/t XX 1969 350 255 4 m/t XY 1969 350 255 4 turbohydro XZ 1969 350 255 4 Powerglide,A.I.R. YA 1968 327 240 4 YB 1968 327 220 4 Powerglide YC 1966 327 220 4 m/t, A.I.R. YC 1968 327 240 4 m/t, A.I.R. YD 1966 327 220 4 Powerglide,A.I.R. YD 1968 327 240 4 Powerglide,A.I.R. YH 1966 327 220 4 hydramatic YH 1967 327 220 4 Powerglide,A.I.R. YHA 2001 346 310 TPI F, Auto, 325hp on SS YHB 2001 346 310 TPI F, Manual, 325hp on SS YJ 1967 327 220 4 turbohydro,A.I.R. YJ 1968 327 240 4 turbohydro,A.I.R. YK 1968 327 240 4 m/t, 3 spd YL 1968 327 240 4 M/t YM 1967 327 220 4 m/t YM 1968 327 240 4 m/t YR 1966 327 220 4 Powerglide YR 1968 327 240 4 Powerglide YS 1966 327 220 4 m/t YS 1968 327 220 4 m/t, 3 spd YSS 1996 350 285 TPI F, Auto, 305hp on SS YST 1996 350 285 TPI F, Manual, 305hp on SS YT 1968 327 220 4 Powerglide YU 1968 327 220 4 m/t, 3 spd YV 1968 327 220 4 M/t YX 1967 327 220 4 m/t ZA 1965 327 275 4 m/t ZA 1969 350 255 4 m/t, A.I.R. ZAA 1979 350 195 4 m/t, L48 ZAA 1992 350 375 MPFI ZR1, ohc, 32v, m/t ZAB 1979 350 195 4 a/t, L48, fed. ZAC 1979 350 195 4 L48, Calif ZAC 1992 350 300 TPI rev cooling, a/t ZAD 1979 350 195 4 L48, high altitude ZAF 1979 350 195 4 L48, m/t ZAH 1979 350 195 4 L48, a/t ZAJ 1979 350 195 4 L48, a/t, Calif ZAK 1980 350 190 4 a/t, L48 ZAM 1980 350 190 4 m/t, L48 ZB 1965 327 300 4 m/t, high perf. ZB 1966 327 300 4 m/t, hi perf. A.I.R. ZB 1969 350 255 4 m/t ZBA 1979 350 225 4 m/t, L82 ZBA 1982 350 200 TTBI Cross-fire inject ZBB 1979 350 225 4 a/t, L82 ZBC 1980 350 230 4 a/t, L82 ZBC 1982 350 200 TTBI Cross-fire inject ZBD 1980 350 230 4 m/t, L82 ZC 1966 327 - A.I.R., a/c ZC 1969 350 255 4 m/t ZCA 1980 305 180 4 a/t, LG4 ZD 1966 327 275 4 Powerglide, A.I.R. ZD 1969 350 255 4 Powerglide ZDA 1981 350 190 4 M/t ZDB 1981 350 190 4 a/t ZDC 1981 350 190 4 m/t ZDD 1981 350 190 4 m/t ZDF 1985 350 230 TPI Tuned port inj, a/t ZE 1965 327 - man trans., a/c ZE 1969 350 255 4 m/t ZF 1965 327 300 4 m/t, a/c, hi perf. ZF 1969 350 255 4 turbohydro ZF 1969 350 255 4 m/t ZFC 1984 350 205 TPI Tuned prt inj, a/t ZFD 1984 350 205 TPI Tuned prt inj, m/t ZFF 1984 350 205 TPI Tuned prt inj, a/t ZFM 1984 350 205 TPI Tuned prt inj, m/t ZFN 1982 350 200 TPI Tuned prt inj, a/t ZFN 1984 350 205 TPI Tuned prt inj, a/t ZG 1966 327 325 4 A.I.R.spec hi perf. ZG 1969 350 255 4 m/t, 3 spd ZH 1966 327 325 4 sp hi per, EM, a/c ZH 1969 350 255 4 m/t, 3 spd ZI 1966 327 325 4 special high perf. ZJ 1966 327 325 4 spec high perf, a/c ZJ 1969 350 255 4 turbohydro ZJB 1985 350 230 TPI Tuned prt inj,m/t ZJC 1985 350 230 TPI Tuned prt inj,exp ZJH 1986 350 235 TPI a/t, alum heads ZJJ 1985 350 230 TPI Tuned prt inj, a/t ZJK 1985 350 230 TPI Tuned prt inj, m/t ZJN 1987 350 240 TPI a/t, alum heads ZJR 1987 350 240 TPI m/t, alum heads ZJS 1986 350 235 TPI a/t, alhds, oil cool ZJW 1986 350 235 TPI M/t, alhds, oil cool ZK 1965 327 275 4 Powerglide ZKA 1986 350 235 TPI m/t, alum heads ZKD 1986 350 235 TPI a/t, alum heads ZL 1965 327 300 4 Pwerglide, hi perf. ZLA 1987 350 240 TPI a/t, alhds, oil cool ZLB 1987 350 240 TPI export, al. heads ZLC 1987 350 240 TPI m/t, alhds, oil cool ZM 1965 327 275 4 Powerglide, a/c ZMA 1988 350 240 TPI a/t, alum heads ZMC 1988 350 240 TPI a/t, alhds, oil cool ZMD 1988 350 240 TPI m/t, alhds, oil cool ZN 1965 327 300 4 glide, a/c, hi perf. ZO 1968 307 200 2 M/t ZP 1968 307 200 2 M/t ZQ 1968 307 200 4 M/t ZRA 1989 350 240 TPI m/t, alhds, oil cool ZRB 1989 350 240 TPI a/t, alum heads ZRC 1989 350 240 TPI a/t, alhds, oil cool ZRJ 1990 350 380 MPFI ZR1, ohc, 32v, m/t ZS 1968 307 200 2 M/t ZSA 1990 350 250 TPI a/t, alum heads ZSB 1990 350 250 TPI m/t, alum heads ZSC 1990 350 250 TPI a/t, alhds, oil cool ZTA 1991 350 245 TPI a/t, alum heads ZTB 1991 350 245 TPI m/t, alhds, oil cool ZTC 1991 350 245 TPI a/t, alhds, oil cool ZTD 1991 350 375 MPFI ZR1, ohc, 32v, m/t ZTH 1991 350 375 MPFI ZR1, ohc, 32v, m/t ZTJ 1991 350 375 MPFI ZR1, ohc, 32v, m/t ZTK 1991 350 375 MPFI ZR1, ohc, 32v, m/t ZUA 1992 350 300 TPI rev cooling, a/t ZUB 1992 350 300 TPI rev cooling, m/t ZVA 1993 350 300 TPI rev cooling, a/t ZVB 1993 350 300 TPI rev cooling, m/t ZVC 1993 350 375 MPFI ZR1, ohc, 32v, m/t ZX 1968 307 200 2 m/t, 3 spd ZY 1968 307 200 2 m/t, 3 spd |
Posted on: 2013/1/19 16:28
Only the corvette LT1 came with 4 bolt mains... all others had 2 bolt mains. All LT4s had 4 bolt mains.
Posted on: 2013/1/19 20:50
From what information I have, the engine stamping with a "Z" were from 1965 thru 1993 all 1994 blocks were stamped with a "W" WCB, WCC, WHD, WHF, WTA, WTB, WTC, WTD.
FYI I did receive an e-mail from a transmission specialist that informed me that GM never offered a RED transmission case. He did state that it implies the trans was rebuilt as many rebuilders repaint the cases to there liking and for a clean appearance. |
Posted on: 2013/1/20 16:20
