81 user(s) are online (53 user(s) are browsing Forums)
Sheet Molded Compound.
The onl...
woody3882 Head numbers?
Florida
51 Posts
1994 LT1 I just found the right engine head number when I was changing the coil which is mounted on the front of the head. The head number is stamped on the front of the head. Does the head number match up with the VIN, or is it unrelated. Just wondering..
Thanks
Posted on: 2013/3/18 20:50
vetteoz Re: Head numbers?
Not sure about any " stamped" numbers on the heads but the block pad above the water pump usually has a partial VIN stamped which identifies the original vehicle the engine was fitted to
Posted on: 2013/3/18 22:20
bogus Re: Head numbers?
and that moves around... it might be there, or on a pad near the oil filter... flip a coin on that one.
There are no "matching" numbers for heads... and in the world of C4s, no one really gives a rot.
Posted on: 2013/3/19 3:25
woody3882 Re: Head numbers?
Florida
51 Posts
I easily located the numbers on the engine block, same location as in your picture, but I have aluminum heads and the numbers are stamped in front on the head just above the numbers on the block pad. The block numbers do not partialy match up to VIN so I have to assume it is a replaemnet motor..
Woody
Posted on: 2013/3/19 6:20
don't make that assessment... you really need to check the numbers down by the oil filter housing. I will check my old block and give you an exact location.
Posted on: 2013/3/19 13:26
Only ever seen the rear location used on late LT1 blocks
Posted on: 2013/3/21 13:14
Matatk Re: Head numbers?
What are the numbers on the head?
Posted on: 2013/3/21 15:46
Florida
51 Posts
The numbers on the head are 26332
The numbers on the engine block pad are V0924WHF which my understanding is the 0924 means Sept,24 and the WHF is the designation for a 350 c.i. 275 h.p. TPI-F
The last seven on the VIN are 5107979 I am going to try and find numbers by the oil filter today.
Posted on: 2013/3/21 16:01
BrianCunningham Re: Head numbers?
NCRS is actually judging C4's now
finding a stock Cross-fire is geeting kind of hard
Peterson Museum had trouble finding one for their big show
Posted on: 2013/3/21 17:04
