2colors | will the digital dash cluster work with out the computer | ||
will the digital dash cluster in a 84 corvette work with out its computer
Posted on: 2013/5/23 1:49
vetteoz | Re: will the digital dash cluster work with out the computer | ||
Only thing on the dash in your car related to the ECM is the fuel mileage and range readout.
Everything else comes from independent sources ,tacho from the coil, gauges from their sender units , speedo from the VSS in the trans ,etc |
Posted on: 2013/5/23 2:44
bogus | Re: will the digital dash cluster work with out the computer | ||
welcome aboard 2colors!
And Oz is right, even if his toilets flush backwards. |
Posted on: 2013/5/23 17:58
Still ends up in the same place though |
Posted on: 2013/5/24 4:46
2colors | Re: will the digital dash cluster work with out the computer | ||
thats awesome that means checking wires which i dont mind.
you see the you see the previous owner burnt up the crossfire injected motor so he replaced it with an old school 350 from a 70's sierra he also put a Rochester 750 Quadrajet and camel heads sadly he put a three speed transmission instead of 4 I'm not sure but I'm willing to bet that there wasn't enough room he also f***** up a lot of the wiring so when I got it nothing electronic work I spend my weekends testing wires and looking for schematics I got 90 percent of electronics working again on the vehicle excluding the digital dash cigarette lighter in the air conditioning and heating |
Posted on: 2013/6/2 14:46
LD85 | Re: will the digital dash cluster work with out the computer | ||
Yes, when I installed my FAST XFI, I only lost instant mileage and MPG
Dash is powered, essentially by the wires coming from the starter |
Posted on: 2013/6/3 0:28
2005/Z51 |
wow, dude, you have a helluva project ahead of you. Good luck with that hack job!!! |
Posted on: 2013/6/3 3:07
well the vette runs an drive just fine i just i want the dash to work
Posted on: 2013/6/3 21:15
CentralCoaster | Re: will the digital dash cluster work with out the computer | ||
Do you have the factory wiring diagrams? If not you're going to be pulling your hair out for years. I have them, not sure the best way to get them to you. Do you have dropbox or usendit? |
Posted on: 2013/6/5 15:26
no sir but you can email them to me at JEBrown1983@yahoo.com i'd love all the help i can get i very good at fixing deadhead wiring
Posted on: 2013/6/5 23:07
i got a haynes manual but it dont tell me enough like for instances the ac power relay location. they dont have a location an the got about 4 or 5 relay just underneath the hood an the same amount in side the car an the manual wont spill the beans on the location but they'll tell you there is one on the schematic
Posted on: 2013/6/5 23:23
can any one tell me if is bad
Posted on: 2013/6/14 16:54
not from this angle. IS that a bulb or what?
I don't see signs of burn, tho. nothing black and crispy. |
Posted on: 2013/6/14 18:38
i dont know what was in there. Its solder into the board its got wire bundled in the center an had some form of tape around it but not over it.The hole it went into is stuff with paper are card board an is taped over with high heat tape. the sight confused me i took a pic
Posted on: 2013/6/14 21:26
