DaleD | oil pan prep. | ||
I bought a newer oil pan for my 87. In great shape, used from vette2vette. I'm going to repaint the outside with engine black paint. It doesn't need it, but since I can, and it's easy, I will. As for the inside, should I do anything to clean/prep it?
Posted on: 2008/2/25 23:54
bogus | RE:oil pan prep. | ||
Clean the entire pan with simple green and rinse with a hose.
The inside needs to be lightly oiled so it won't surface rust... it just looks ugly, too. The outside, clean with laquer thinner and then paint. Use high-temp engine paint from a rattle can. Works surprisingly well. I would warm the paint and the pan... if you can put the pan into a slow oven, say, 100F, that will help a lot... the paint can be rested in a bowl of hot water before use. |
Posted on: 2008/2/26 6:13
Midnight85 | RE:oil pan prep. | ||
Perfect advice!
Posted on: 2008/2/26 15:36
HORSEPOWER! Some is good, more is better, too much is just right. |
BillH | RE:oil pan prep. | ||
Yea, what Bogus said. You can also use WD40 on the inside of the pan, they don't call it Water Displacement 40 for nothing. Spray it on a rag and wipe to keep it off the outside.
I use the "warming up the paint in the sink" technique all the time. 2-3 light coats with ample drying time are better that 1 heavy coat. |
Posted on: 2008/2/26 16:54
