252 user(s) are online (202 user(s) are browsing Forums)
j3studio [Another C4 Thought Experiment] Increasing Long Range Comfort
What are folks thoughts on increasing long range travel comfort in a C4 while remaining reasonably stock? In other words, what parts could I replace on an almost 29 year old car that will yield the greatest return?
Some thoughts, in no particular order:
1) Shocks (Delco-Bilstein) and tires (BFGoodrich) are relatively new.
2) An alignment was performed earlier this year by the experts in the area.
3) I was hyped on replacing the (probably orginal) rubber bushings until Central Coaster told me they would help the car handle better but would be substantially less comfortable.
4) I intend to get the Solar Shades that Guru vendor Mid America offers to keep the heat down.
http://www.mamotorworks.com/corvette?frame=3.704
5) Air conditioning is fully charged, with no leaks.
Posted on: 2013/8/4 19:13
bogus Re: [Another C4 Thought Experiment] Increasing Long Range Comfort
the rest depends on maintence history.
go to your prior thread and check my list compared to your work already...
start there...
Posted on: 2013/8/5 0:47
btw, the banski setup will not hurt ride quality. if anything, it improves it by freeing up the suspension.
Posted on: 2013/8/5 0:52
a few more thoughts...
I would pull out the seats and carpet, and put down a layer of insulation on the floor and trans tunnel.
Also, there is a specific heat wrap material available for over the trans under the car. It sticks to the hump from the underside.
Pretty much anything that can be done to improve cabin quiet and cool will help tons.
Also, does your car have the heavy duty cooling system? If so, that means it has a oil "cooler". It uses coolant to keep the oil temp down. A small heat exchanger exists as the oil filter housing. Come to think of it, they all may have this.
However, there are several hoses that connect all of that together. I would replace them.
Pressure wash the engine, clean engines run cooler, less goo to trap heat.
Replace any rubber vacuum hose you can see... they are getting brittle with age, and usage may cause them to fail.
Posted on: 2013/8/5 19:23
j3studio Re: [Another C4 Thought Experiment] Increasing Long Range Comfort
Also, there is a specific heat wrap material available for over the trans under the car. It sticks to the hump from the underside. Pretty much anything that can be done to improve cabin quiet and cool will help tons.
Also, does your car have the heavy duty cooling system? If so, that means it has a oil "cooler". It uses coolant to keep the oil temp down. A small heat exchanger exists as the oil filter housing. Come to think of it, they all may have this. However, there are several hoses that connect all of that together. I would replace them.
Good stuff, Andy, thanks!
hello2
Posted on: 2013/8/5 22:27
BillH Re: [Another C4 Thought Experiment] Increasing Long Range Comfort
Pressure wash an engine that has 85 electronics and wiring?
Posted on: 2013/8/5 22:50
hell yea.
if there is going to be a wiring related failure, find it now and not somewhere in the middle of who knows where... in the middle of a pouring rain.
Posted on: 2013/8/6 0:24
If you want.
I NEVER powerwash an engine that's in the car. Just a dumb thing to do.
Posted on: 2013/8/6 0:37
So, for your trip, you need to repair or purchase:
Head gaskets
Transmission rebuild/flush
Replace all belts and hoses
Flush coolant
change oil,
replace alternator
replace all ujoints.
replace all wheel bearings.
Service brakes.
replace radiator
replace cooling fan motor(s)
recharge AC
flush ps fluid
replace all exterior bulbs
replace all 8 main injectors
new air filter
replace heater core
new water pump
complete tune-up (plugs/cap/wires/rotor)
new fuel pump
new fuel filter
Install a trailer hitch
Install the banski rear suspension.
New shocks
Install an oil cooler
Change all the vacuum lines.
Buy a trailer and haul:
Serp belt
* serp belt tool
* duct tape
* 2 rolls, electrical tape
* assortment of fuses
* Battery jump box
* assorted hand tools
* fix-a-flat and a puncture repair kit
* 12v air compressor
* can of brake fluid
* 2 quarts of oil
* gallon of 50/50 coolant
* gallon of distilled water
10 gallons of gas
A gun
A satellite phone.
You could put price guesses on these just for fun and add up the cost of driving the equivalent distance of ONE OIL CHANGE.
Posted on: 2013/8/6 1:45
Calm Re: [Another C4 Thought Experiment] Increasing Long Range Comfort
Vancouver, Canada
608 Posts
FINALLY someone said it!
'course it was Bill....but whatever.
Posted on: 2013/8/6 3:20
[Edited for markup, with bold for done, and italics for partially done]
Head gaskets
Flush coolant change oil
Replace alternator [2004]
Replace all ujoints [should definitely do anyway]
Replace all wheel bearings [should probably do anyway]
Service brakes [2010]
Replace radiator
Replace cooling fan motor(s)
Recharge AC [2010]
Flush ps fluid [2010]
Replace all exterior bulbs [2011]
Replace all 8 main injectors [2009]
New air filter [2010]
Replace heater core [Nooooo!]
New water pump [2011]
Complete tune-up (plugs/cap/wires/rotor) [2010]
New fuel pump
New fuel filter [2009]
New shocks [2005]
Install an oil cooler [part of the Z51 in 1985]
* Serp belt
* Serp belt tool [good idea]
* duct tape
* Assortment of fuses
* Battery jump box [I bought the one BillH suggested]
* Assorted hand tools
* 2 quarts of oil [I carry 1 quart all the time]
* 10 gallons of gas
* a gun [I haven't had one for years]
* a satellite phone
Short form: it sounds like a ton of stuff, but I've done the maintenance or am carrying a lot of the stuff already.
Posted on: 2013/8/6 12:34
That's the jest of it, if you've kept up the maintenance, just fill the gas tank and take your trip.
Posted on: 2013/8/6 12:58
that and the fact that bill cut/paste my list...
Posted on: 2013/8/6 14:09
pianoguy Re: [Another C4 Thought Experiment] Increasing Long Range Comfort
I would resist any temptation to use a rooftop luggage carrier:
Posted on: 2013/8/6 18:43
pianoguy wrote:
I would resist any temptation to use a rooftop luggage carrier ...
We managed 13 days in 2008 with only what we could carry under the rear hatch - and we pack better now.
Posted on: 2013/8/6 19:51
There is a lot of room in the hatch of a C4... a lot of room.
Posted on: 2013/8/6 21:52
corvetteronw Re: [Another C4 Thought Experiment] Increasing Long Range Comfort
Lowell, MI
There was an article in one of the Corvette rags a few years ago about a company that made electrical heating grids that would give you heated seats for those cold mornings.
You remove your seat covers and place these between the leather and the foam. They have them for the seat cushions and the backs too.
A Google search might find the supplier for you.
Do you have a satellite radio setup? I had XM in my old truck and loved to be able to listen to all the baseball and football games as I travelled. The only drawback is that you would lose the signal if tall mountain peaks or forests blocked out the satellite. XM also had stations that would perform plays such as mysteries, comedies, drama for you. My grandkids loved listening to the kids shows too.
Posted on: 2013/8/8 4:40
corvetteronw wrote:
There was an article in one of the Corvette rags a few years ago about a company that made electrical heating grids that would give you heated seats for those cold mornings. You remove your seat covers and place these between the leather and the foam. They have them for the seat cushions and the backs too.
Do you have a satellite radio setup? I had XM in my old truck and loved to be able to listen to all the baseball and football games as I traveled. The only drawback is that you would lose the signal if tall mountain peaks or forests blocked out the satellite. XM also had stations that would perform plays such as mysteries, comedies, drama for you. My grandkids loved listening to the kids shows too.
Thanks, Ron.
Posted on: 2013/8/8 21:18
if you do sat radio, make sure the RF interface is direct through the antenna cable, not via a low level ground signal.
The low level signals do not work worth a damn. The direct via antenna interface is the only way to go.
I am going to do bun warmers in both the Suburban and bastet44's Vette when I get back to working on it.
Posted on: 2013/8/9 16:54
