191 user(s) are online (94 user(s) are browsing Forums)
biggrizzly !/2 Turn or 1/4 Turn?
Comp Pro-Mag 1.6 roller rockers - using comp nuts/polylocks
3/8" studs
I got them set at 1/2 turn now. I read a couple threads elsewhere that some are setting at 1/4 turn. Sounds like too little preload, but what worked for you?
Posted on: 2008/2/25 18:21
byebyeL98 RE:!/2 Turn or 1/4 Turn?
Orange County, NY
41 Posts
Either is fine. The key is making sure you are at zero lash AND on the base circle of the lobe for the rocker you are adjusting.
I usually go 1/4 turn, tighten the lock nut, then snug the rocker nut another 1/8th.
Posted on: 2008/2/25 18:57
biggrizzly RE:!/2 Turn or 1/4 Turn?
Once the poly lock is tightened the rocker nut aint budging on mine. What is the advantage to only going 1/4 turn? Is it an issue that the valves won't fully close if too much preload is adjusted into it??
Thanks
Posted on: 2008/2/25 20:31
fnsblum RE:!/2 Turn or 1/4 Turn?
Nothern Utah
32 Posts
No advantage at all. If you rev it high enough to float the valves it doesn't make any difference what the preload is. Later! Frank
Posted on: 2008/2/25 21:36
93 Red LT-1
Bought in Nov.
First mod is a set of Magnaflows.
dan0617 RE:!/2 Turn or 1/4 Turn?
I have the stock lifters with a CC503 cam and Summit 1.6 rockers. I went 1 full turn with mine as that is what is suggested in the repair manual. I have hit the rev limiter several times setting up the trans governor and am now shifting near 6000 rpms and have not heard the slightest sign of valve float or have any problems at all. I was really considering 1/2 turn but I figured since I used the stock lifters I'd use the stock preload. I don't know of any advantage of going with less than 1 turn of preload, does anyone else?
Posted on: 2008/2/25 23:47
cuisinartvette RE:!/2 Turn or 1/4 Turn?
Usually go 1/2
Posted on: 2008/2/25 23:54
JAKE266 RE:!/2 Turn or 1/4 Turn?
Kempner, Texas
22 Posts
Anyone read TPIS' positive results by setting preload at TWO FULL TURNS FROM ZERO?
Jake
Posted on: 2008/2/26 18:57
__________________
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
Jake
Got a link? or reference?
Posted on: 2008/2/26 19:21
I've heard they suggest 2 full turns. I think that is too much. Too close to the bottom of the lifter in my opinion, then if you do have a lifter pump up at high rpm's you are risking piston to vavle clearance. I was going to go with 1/2 turn but decided to do 1 full turn. Next time the rockers are off I want to try 1/2 turn but I had so many variables this time with swapping everything above the block including the full ignition system I really wanted to go with a preload I had ran previously with the same lifters. So far so good.
Posted on: 2008/2/26 20:38
TimAT RE:!/2 Turn or 1/4 Turn?
Gladstone, MO (Kansas City)
38 Posts
I've always used 1/4 turn. I set them running too. Back off until they rattle, tighten until they just quit making noise, then 1/4 turn. I've turned hydraulic lifter engines to 7k setting them this way with no problems.
The idea is to get the pluner inside the lifter just barely above centered. Too low and they will "pump-up" they can't bleed down fast enough. too high and they bleed too fast and collapse.
Setting them running is a bit messy, but the guesswork goes right in the drain too.
Posted on: 2008/2/26 21:25
vettef6 RE:!/2 Turn or 1/4 Turn?
Germany
8 Posts
I just did mine with 1/2 turn, even though Crane says 1 1/2 turns. I also let the engine run while adjusting the rockers.
Like TimAT said, it's a little messy but it's the only way of doing it right.
Arnold
Posted on: 2008/2/26 22:07
92 LT1, ZF 6 sp. 397ci, Ross pistons, heavily ported 210cc LT4 AFR heads, ported LT4 intake, 1.6 RR, SR 247/255 .664/.664 112°, 11.3:1 CR, 58mm TB, 36# injectors, Fidanza alum. fw, Hooker 1 3/4" lt headers, no cats, self made dual SS 3" exhaust, X-pi...
Danspeed1 RE:!/2 Turn or 1/4 Turn?
Mooresville, North Carolina
1121 Posts
Arnold
:me2:
Thats the way I was taught to do it in school. On my 85 monte i did it without the car running and i guess it came out alright. Next time i do this i am going to get a set of valve covers and cut holes in it in accordance to the locks. Then i am going to tighten it down that way. Whats nice about doing it with the car running is you can actually hear when it is correct.
DG
Posted on: 2008/2/26 23:40
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
