193 user(s) are online (126 user(s) are browsing Forums)
kenvetted Driver side window stuck up
santa monica
13 Posts
In my 1991 C4 the window is now stuck up, thankfully better than can't getting it up.
The motor is running and makes a clicking rumbling sound, but the window won't move.
My question is... should buy a new window regulator before I take off the door panels? It's about $279 http://www.parts123.com/parts123/yb.d ... 35a~Z5Z5Z5~Z5Z5Z50000050F
Or since the motor is still working is it possible that the window fell off the track somehow and I can make it work again?
The other question is - Are the other parts that I should replace outer weather stripping and felt guides or such since the panel will be off?
- Any help is greatly appreciated - yes I know about the innuendo at the top, no need to make jokes.. I did it for you.
If you know a good service place in LA area that may just be the best, because it may too hard a job for me. But I just don't trust any mechanic to be as careful as I am -
Thanks,
Ken
Posted on: 2013/8/19 5:28
bogus Re: Driver side window stuck up
no need for a regulator... the motor is replaceable. About $30
each.
Posted on: 2013/8/19 5:41
TommyT-Bone Re: Driver side window stuck up
33770 Posts
Here is a trick Bubba taught me. From the drivers seat with the door open, press the down button and firmly close the door at the same time. Try it a couple of times. You have nothing to lose. If it works, lubricate all the moving parts and tracks accordingly.
Posted on: 2013/8/19 12:02
j3studio Re: Driver side window stuck up
TommyT-Bone wrote: Here is a trick Bubba taught me. From the drivers seat with the door open, press the down button and firmly close the door at the same time. Try it a couple of times. You have nothing to lose. If it works, lubricate all the moving parts and tracks accordingly.
Interesting ...
Posted on: 2013/8/19 13:26
hslf way there, Tommy...
what it reveals is a stuck brush in the motor. lube might help, but I know this car. it is a PERFECT 31k mile time capsule...I am afraid some parts may be aging out.
Posted on: 2013/8/19 16:24
kenvetted Re: Driver side window stuck up
santa monica
13 Posts
Thanks so much...
Bogus - The motor seems to be working. It's making a grinding sound. I may try (J3Studio's idea) closing to the door with the Window motor on... My fear is that I won't be able to get the window up again. But that you would mean that the window is off the track. I was rattling a lot in a midway position before this happened. Is worth trying the slamming and if that doesn't work should I buy the regulator before taking off the door? How hard is the Door Panel Removal?
Posted on: 2013/8/19 17:09
there is no "track" with these things.
Grinding? that sounds like the internal drive of the motor has broken... same replacement, tho.
Rattling is absolutely normal with these doors. the glass is free floating and rattles like an SOB.
I wouldn't mess with it until you can get the door panel off and investigate. Let me check my schedule, perhaps Saturday you can stop by.
Posted on: 2013/8/19 19:57
