istter1 | Bob's Tuned Port Single Plane Intake/// is this worth doing | ||
http://forums.corvetteforum.com/c4-pa ... -single-plane-intake.html
Been searching for an answer to need for more speed and still being Ca complaint/ Can't use the new Eddlebrock not Ca again, Can't find the acellSuper Ram intake, http://forums.corvetteforum.com/c4-pa ... ed/3351540-super-ram.html what would be a good offer advice please Steve |
Posted on: 2013/10/19 17:03
76Nordic | Re: Bob's Tuned Port Single Plane Intake/// is this worth doing | ||
Dumbass
Don't have an answer, but do have a curiosity question. Is that plumbers tape holding the valve cover breather down?
Posted on: 2013/10/19 18:02
The Definition of insanity; Doing the same thing over and over again, and expecting different results.....Einstein |
BrianCunningham | Re: Bob's Tuned Port Single Plane Intake/// is this worth doing | ||
Doesn't look like it has an EGR
Posted on: 2013/10/19 18:07
istter1 | Re: Bob's Tuned Port Single Plane Intake/// is this worth doing | ||
not my car |
Posted on: 2013/10/19 18:30
Matatk | Re: Bob's Tuned Port Single Plane Intake/// is this worth doing | ||
How is that CARB compliant?
Posted on: 2013/10/19 20:13
bogus | Re: Bob's Tuned Port Single Plane Intake/// is this worth doing | ||
it's not.
No EGR. The super ram was made by Accel/Edelbrock/Lingenfelter. And that looks like a piece of metal strap, screwed into the valve cover. ebay is dead... nothing there. Edelbrock makes something... http://www.summitracing.com/parts/edl ... /chevrolet/model/corvette and... http://www.summitracing.com/parts/edl-3865/overview/ problem solved. Much nicer than stock. Get the inside of your plenum cleaned up and you're done. |
Posted on: 2013/10/19 23:49
I just got back from the drags and showed the picture to edlebroch booth. The first words were what the hell is that. They sent an email on my phone asking for testing and stats on air flow and a few other question.
Wonder if he will answer. I told them I would forward the reply. Funny |
Posted on: 2013/10/20 3:29
Edited by istter1 on 2013/10/20 3:47:12 |
Wonder if he will answer. I told them I would forward the reply. Funny Attach file: 20131019_160746.jpeg (263.01 KB) 20131019_163908.3gp Size: 588.24 KB; Hits: 161 20131019_171803.jpeg (282.92 KB) |
Posted on: 2013/10/20 3:31
vetteoz | Re: Bob's Tuned Port Single Plane Intake/// is this worth doing | ||
Matatk wrote: Only way would be to add the EGR valve http://www.tpis.com/pages/10_12_08 |
Posted on: 2013/10/20 11:57
Ok Andy the runners are $450 Edelbrock Pro-Flo XT EFI Intake Manifolds 7138 is $409 you could add the EGR from tpis. would California your smog guy know the difference http://www.tpis.com/parts/view/55 Attach file: EDL-7138.jpg (11.24 KB) EDL-3865runners.jpg (8.36 KB) egr.jpg (6.91 KB) |
Posted on: 2013/10/20 16:44
ok... you picked the only three parts in the world that don't mix.
The 7138 is complete, but without EGR. And CARB frowns upon relocating this crap... I know, annoying. The parts I listed would work and all have CARB OE numbers. That's where you get into trouble. The EGR relo kit is designed to go with the TPiS intake. But that EGR relo won't work... and you won't need the runners with that intake. It is designed to be used with this intake: http://www.tpis.com/parts/view/33 The mini-ram... expensive cuss, tho. As expected, the EGR isn't CARB legal, but, if it's there, I doubt many sniffers will give a damn. |
Posted on: 2013/10/20 17:50
Knew I wouldn't need the runners. SOL again When someone has a lead on a CARB legal unit mini ram let me know still searching |
Posted on: 2013/10/20 19:44
personally, I think the mini ram with an EGR would pass... you just need a friendly smog guy to ignore the hardware and accept the numbers.
Posted on: 2013/10/20 20:18
Well I have the smog guy. He is as old as me so I guess I would just have to keep my old stuff. Thanks Mat after seeing what TPIS charges to make a custom chip I got a hell of a deal from PCM of NC. " TPIS offer custom programmed chips for 85-93 Corvette, Camaro, Firebird, and street rod applications using the Tuned Port or LT1 system. We also custom program the GM flash ECM for the 94-97 LT1, and the entire LS1 and LS2 based formats from 97-08. For the flash computers you must send your computer to us for recalibration, but for the early chipped computers we just send out a new chip. We can configure a program that will run a stock engine with emissions and vehicle anti-theft deleted for a street rod application all the way to a fully customized program to control a 500+ horsepower drag race engine. Just call us with your specs. Pricing is as follows. Level 1: Stock tune with VATS and emissions delete for street rod ............$175.00 Level 2: Perf. tune for stock engine (can include Level 1 mods) ..................$275.00 Level 3: Lots of bolt-ons, throttle body, exhaust, etc. ......................................$375.00 Level 4: Aftermarket intake, MiniRam, cam, & all bolt-ons ............................$475.00 Level 5: Larger engines, cam & heads,forced induction ...............................$575.00" Thanks guys good discussion . |
Posted on: 2013/10/20 20:44
Edited by istter1 on 2013/10/20 21:14:30 Edited by istter1 on 2013/10/20 21:18:00 |
Before my superram I had an edelbrock big mouth base and slp runners. Both carb legal. With my porting my car topped out around 5400 rpms. I was happy with what it was, but not as happy as the superram.
http://www.jegs.com/i/Edelbrock/350/3860/10002/-1 http://www.slponline.com/product/2000 ... ebird-Intake-Runners.html |
Posted on: 2013/10/21 2:45
Well the runners are priced right $329 and free shipping I want the supper Ram but I have only seen one and it was tricked out and almost 3 grand Thanks Mat |
Posted on: 2013/10/21 4:08
The superram on cf right now was extrude honed and I think he wants 1355 plus shipping with injectors and TB. Not a bad price.
Keep an eye on TGO as well, that is where I found mine. |
Posted on: 2013/10/21 11:18
Granted but plenty have used it for a retrofit on other than a MR. All you need is a flat surface on the plenum somewhere large enough to mount the base There are plenty of compact OEM valves that could be remote mounted so only a line to a port threaded into the plenum would be required. The options are limitless |
Posted on: 2013/10/21 12:21
good point. A little machining and some screws... done.
Posted on: 2013/10/21 20:02
I do have a roll of plumbers tape
Posted on: 2013/10/22 1:01
Not sure of it's resistance to EGR gas temps ? |
Posted on: 2013/10/22 1:54
Holley Stealthram
Street PerformanceComing Soon! http://www.holley.com/types/Avenger%2 ... ealth%20Ram%20Systems.asp I hear clearance problems any info on Ca emissions or price Altering a Holley Stealth Ram to fit a C4, lots of pics http://www.digitalcorvettes.com/forums/showthread.php?t=59726 |
Posted on: 2013/10/22 1:57
Edited by istter1 on 2013/10/22 2:17:03 |
Would require the same EGR solution as above You only buy the HSR intake and fuel rails , reusing all your TPI stuff http://www.summitracing.com/int/parts/wnd-7540/overview/ http://www.summitracing.com/parts/HLY-534-186/ Quote:
Excuse for that hood scoop you always wanted |
Posted on: 2013/10/22 4:52
Hood scoop Lol http://www.bbkperformance.com/news_item.php?nak=23 In devolepmentBBK |
Posted on: 2013/10/22 5:45
that first system is a full on EFI, and it's not legal... no aftermarket system is, as I understand it.
If it's CA legal, it will have an EO number. |
Posted on: 2013/10/22 6:35
http://www.thirdgen.org/techboard/tpi ... bbk-tpi-intake-setup.html Has had a long gestation period. Raised a lot of hopes when it was 1st announced. Note the date of the original posting! |
Posted on: 2013/10/22 11:57
To me it seems like you are trying to reinvent the wheel. You know there are two CARB legal intake systems - the edelbrock base (which apparently since it's a "replacement" item doesn't need an EO) along with SLP runners (have EO) and the superram. So why not focus on those?
Posted on: 2013/10/22 15:12
I agree.
Keep this simple to whats known and what works. |
Posted on: 2013/10/22 18:05
