LD85 | C5 Brake Upgrade | ||
I know, it has been done many times before, just wanted to document the lower cost for parts.
Rock Auto C5 Rotors = $50 shipped ($20.99 each) 14x2 mm Bolts = $10.00 C5 Calipers, Brackets & Pads = $190 shipped SS braided brake lines = $100 Conversion brackets made by me = $0 Since these are NOT Z06 Calipers, I have to paint them the color of my choice So I painted them w/ RED & Black caliper paint and left the lettering silver, then clear coated w/1200-degree clear,, painted the retro-brackets too |
Posted on: 2008/3/3 13:34
2005/Z51 |
smooth | Re: C5 Brake Upgrade | ||
Did you strip them all the way down to bare metal, or just spray with brake cleaner?
Posted on: 2008/3/3 14:59
Alan 2001 Navy Blue Metallic Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. Dr.Seuss |
LD85 | Re: C5 Brake Upgrade | ||
Yes, I just cleaned them well with Brake Cleaner and sprayed them with Hi Temp engine paint
Posted on: 2008/3/3 15:03
2005/Z51 |
Came out nice. I've got a set I have to rebuild first, then paint and bolt up.....its on the "to do" list
Posted on: 2008/3/3 15:25
Thanks for getting me off my ars LD !! Got some black caliper paint and went at it ! Going to let it cure overnight before I clean up the logo with some emery paper.
Thanks again LD |
Posted on: 2008/3/3 21:17
No problem, I used a razor blade and cleaned up the lettering,,,
then dont forget to clear coat the Caliper when you are done. I used 1200 degree clear engine paint. |
Posted on: 2008/3/3 21:39
2005/Z51 |
SpectatorRacing | Re: C5 Brake Upgrade | ||
I painted mine a long time ago, but when they got covered in dust I cleaned them with brakecleen and it removed all the paint, too.
Would clear coat protect against cleaners? |
Posted on: 2008/3/5 19:02
aka Scaryfast |
rickreeves1 | Re: C5 Brake Upgrade | ||
Were all the parts bought from Rock Auto?
Posted on: 2008/3/5 19:19
95-Lt1-auto-Polo-Conv, 125hp ZEX N2O dry, LE Cam 226/234 565/565 109LSA, Comp Pro Mag 1.6rr, Patriot Xtreme Springs, PCMFORLESS, K&N, AO Ram Air, 52mm TB, EM LT Headers, X-pipe, Meziere HD EWP, Vigil 2800, TransGo Shift Kit, Pro-Built Trans, 24lb SVO'... |
The 1200 degree ceramic clear coat helped to prevent chipping and is much easier to keep clean, I have not used chemicals on them, have not had to so far...
The rotors are from RockAuto,,, but I got the Calipers and pads from a guy on CF. |
Posted on: 2008/3/6 1:57
2005/Z51 |
