127 user(s) are online (113 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
istter1 fuel relay and raido spratic shut off
Bakersfield Ca
2336 Posts
Radio will turn off and start no apparent problem. Now replaced fuel relay because fuel would shut off. Wiggle wires around it starts up.
Plug wires are suddenly showing cracks and burn marks 8MM.
Is there a chance the plug wires are arcing into other wires.
Can the new 50000 volt coil cause this problem
jpeg  20131221_121656.jpeg (312.07 KB)
5144_538cd29ebce2f.jpeg 1200X1600 px
Posted on: 2014/6/2 19:38
Carol Burnett
bogus Re: fuel relay and raido spratic shut off
hm... lets break this down...
radio... quits, restarts... I would suggest checking the relay.
Fuel pump relay... agreed, replace. it's old.
Which wires are you wiggling?
The burned/cracked wires? Plug wires or what?
FYI: Pre-1990 Corvettes suffer from junk harnesses. The primary wires lose insulation, crack, shrink, chaff, you name it... junk, in short!
Posted on: 2014/6/2 21:36
istter1 Re: fuel relay and raido spratic shut off
Bakersfield Ca
2336 Posts
Ya plug wires on drivers side all cracked up..
Looks like after replacing the fuel pump relay. Fuel pressure is correct now the problem is a bad wire to the distributes Found it 10 minutes ago
will fix in morning tired and been a long day/
Thanks Andy
Posted on: 2014/6/3 5:42
Carol Burnett
Matatk Re: fuel relay and raido spratic shut off
Glad you found the problem.
See if that fixes your radio problem, as well. Distributors have cause radio problems in the past.
Posted on: 2014/6/3 13:53
The high voltage around a distributor can set off all sorts of noise...
Check out MSD or Taylor wires.
Posted on: 2014/6/3 17:54
Bakersfield Ca
2336 Posts
Replacing HEI wire. To dam hot here 100 already. Waiting a little bit for it to cool down. Uses a gm extension alternator pig tails with a little modification. Fits tight.
Just need to tighten down the Dizzy cap.
and cross my fingers
Posted on: 2014/6/3 22:46
Carol Burnett
Bakersfield Ca
2336 Posts
For now replacing the EFI no stalling no turning off no loading up
time for a new raido
Posted on: 2014/6/4 0:51
Carol Burnett
EngineDoctor Re: fuel relay and raido spratic shut off
La Habra Ca.
791 Posts
I think that diet coke was the problem !
Posted on: 2014/6/4 2:16
Bakersfield Ca
2336 Posts
Strong stuff Dave
Posted on: 2014/6/4 6:56
Carol Burnett
Is the radio aftermarket?
Could be as simple as a bad connection.
Posted on: 2014/6/4 13:00
hcbph Re: fuel relay and raido spratic shut off
269 Posts
Yup! Unless it's the real thing, everything goes crap on you.
Posted on: 2014/6/4 13:03
Bakersfield Ca
2336 Posts
It is after market Today no problems.Son Mess with plug said I am wrong taking it tomorrow to a shop to check it out. If it is deck they will sell me a new one.
Posted on: 2014/6/4 20:12
Carol Burnett
I highly doubt it is the unit itself. I would double check all the wiring and harness connector.
Posted on: 2014/6/5 3:16
