istter1 | fuel relay and raido spratic shut off | ||
Radio will turn off and start no apparent problem. Now replaced fuel relay because fuel would shut off. Wiggle wires around it starts up.
Plug wires are suddenly showing cracks and burn marks 8MM. Is there a chance the plug wires are arcing into other wires. Can the new 50000 volt coil cause this problem |
Posted on: 2014/6/2 19:38
bogus | Re: fuel relay and raido spratic shut off | ||
hm... lets break this down...
radio... quits, restarts... I would suggest checking the relay. Fuel pump relay... agreed, replace. it's old. Which wires are you wiggling? The burned/cracked wires? Plug wires or what? FYI: Pre-1990 Corvettes suffer from junk harnesses. The primary wires lose insulation, crack, shrink, chaff, you name it... junk, in short! |
Posted on: 2014/6/2 21:36
istter1 | Re: fuel relay and raido spratic shut off | ||
Ya plug wires on drivers side all cracked up.. Looks like after replacing the fuel pump relay. Fuel pressure is correct now the problem is a bad wire to the distributes Found it 10 minutes ago will fix in morning tired and been a long day/ Thanks Andy |
Posted on: 2014/6/3 5:42
Matatk | Re: fuel relay and raido spratic shut off | ||
Glad you found the problem.
See if that fixes your radio problem, as well. Distributors have cause radio problems in the past. |
Posted on: 2014/6/3 13:53
The high voltage around a distributor can set off all sorts of noise...
Check out MSD or Taylor wires. |
Posted on: 2014/6/3 17:54
Replacing HEI wire. To dam hot here 100 already. Waiting a little bit for it to cool down. Uses a gm extension alternator pig tails with a little modification. Fits tight.
Just need to tighten down the Dizzy cap. and cross my fingers |
Posted on: 2014/6/3 22:46
For now replacing the EFI no stalling no turning off no loading up
time for a new raido |
Posted on: 2014/6/4 0:51
EngineDoctor | Re: fuel relay and raido spratic shut off | ||
I think that diet coke was the problem !
Posted on: 2014/6/4 2:16
Strong stuff Dave |
Posted on: 2014/6/4 6:56
Is the radio aftermarket?
Could be as simple as a bad connection. |
Posted on: 2014/6/4 13:00
hcbph | Re: fuel relay and raido spratic shut off | ||
Yup! Unless it's the real thing, everything goes crap on you. |
Posted on: 2014/6/4 13:03
It is after market Today no problems.Son Mess with plug said I am wrong taking it tomorrow to a shop to check it out. If it is deck they will sell me a new one. |
Posted on: 2014/6/4 20:12
I highly doubt it is the unit itself. I would double check all the wiring and harness connector.
Posted on: 2014/6/5 3:16
