273 user(s) are online (216 user(s) are browsing Forums)
PeteK 700R4-4L60 Build Up Part 6
It has been years, but I finally installed this transmission on Friday.
Initial driving impressions are good.
No gear whine, leaks or other oddities.
Although I noticed the closer ratios at part throttle, most would not.
Time to inspect my antique drag radials, and see if they will be soft enough for 1 more weekend.
Track results and WOT impressions pending.
Posted on: 2014/8/10 12:52
Matatk Re: 700R4-4L60 Build Up Part 6
Do you have any mph/number comparisons yet for the ratio change? Both actual ratios and results from driving?
Posted on: 2014/8/10 13:28
PeteK Re: 700R4-4L60 Build Up Part 6
3rd gear remains 1:1 and 4th gear remains .70 so cruising is unchanged.
Posted on: 2014/8/10 13:41
1st and 2nd are the key, though. I think the stock 1st gear is 3.06 and I hate the shift from 1-2 at 8 mph.
Posted on: 2014/8/10 15:07
Now it is 2.84 for first, and 1.56 for second.
On paper, pretty nice.
Posted on: 2014/8/10 15:09
Is it the same gear set from patc?
Posted on: 2014/8/10 15:14
They market and distribute it, but Chris at CK Transmissions was the brains behind it, and is responsible for the manufacturing.
Posted on: 2014/8/10 15:44
bogus Re: 700R4-4L60 Build Up Part 6
That sounds more like a 4L80 ratio set...
Posted on: 2014/8/10 19:41
It took much longer than I thought, but a quality aftermarket company has knocked off the original gearset.
Less than 1/2 the price I paid, and in line with the price of other transmission types (Turbo 350, powerglide, Turbo 400 etc).
http://www.sonnax.com/parts/3734
Posted on: 2014/10/18 11:39
Have you installed it and tested it yet?
Posted on: 2014/10/18 11:43
Ran out of summer, so no track times yet.
Street driving only.
Posted on: 2014/10/18 11:48
Any impressions as far as driveability? I want to know what difference it makes in the 1-2 shift in a real world application.
Posted on: 2014/10/18 16:00
Posted on: 2014/10/18 16:01
The butt dyno does not notice much of a difference.
I have quite a few datalogs from the last trans, so not only will I be able to compare ET differences, but I "should" be able to quantify the shift point increases (or decreases).
Posted on: 2014/10/18 16:54
Schrade Re: 700R4-4L60 Build Up Part 6
Don't you wanna' move closer to NC here Pete?
I'm not happy with my 4L60e in mine...
Posted on: 2014/10/20 18:22
