291 user(s) are online (247 user(s) are browsing Forums)
bogus Diameter of a pin
Ugh... several weeks back, I survived the hell of swapping the master and booster... yuck.
Last night, apparently, the metal spring clip that retains the booster to the pedal came off - I must not have gotten it on ok last time.
Now, I have lost the damned clip!
I want to use a washer and eclip... but don't know the size of eclip I should use. Washer is easy...
Thoughts?
Posted on: 2014/8/26 16:27
Schrade Re: Diameter of a pin
I've seen multi-packs in the 'Help' section there bogus; been there yet?
This the same as a C-Clip?
Posted on: 2014/8/26 21:50
bogus Re: Diameter of a pin
that's what I was going to get unless I could get the exact size.
Posted on: 2014/8/26 22:27
pianoguy Re: Diameter of a pin
Is that one of those Jeezus clips? Where you say, "Jeezus, where did it go?"
Posted on: 2014/8/27 0:04
yup... I have several other pet names for it, too...
that's just a nice one...
Posted on: 2014/8/27 0:33
BrianCunningham Re: Diameter of a pin
Was there a groove to hold it on?
just like brake caliper pins?
Take a look at McMaster-Carr.com should be able to get what you need
Posted on: 2014/8/27 11:31
yea... M-C has EVERYTHING! I suspect I will hit my local hardware store on Friday (day off). Still faster...
Posted on: 2014/8/27 16:57
If it launched inside of the car, maybe still there?
Think THAT'S frustrating?
I had the tailgate glass off of my liftgate on my GMC. 2 big pins, 2 TINY C-Clips.
At re-assembly, lost one.
(no - not a C-Clip, BUT ONE OF THE PINS!!! )
Posted on: 2014/8/27 17:59
ugh... I hate it when stupid crap like that happens.
I am sure the clip is still there, but getting it on is nearly impossible!
Posted on: 2014/8/27 22:32
hcbph Re: Diameter of a pin
269 Posts
Can't help you with the missing clip but if you're not sure there are multiple packs out there with a variety of sizes in them like this: http://www.harborfreight.com/300-piec ... lip-assortment-67653.html
If you can't find what you need and can figure out the size I can check for you as I have that pack.
Posted on: 2014/8/28 12:40
I was hoping someone had a spare pedal set outside the car.... I will get an assortment...
Posted on: 2014/8/28 15:38
