212 user(s) are online (167 user(s) are browsing Forums)
1st Gear: 2.43
2nd Gear: 1.49
4th Gear: 0.75
Reverse: 2.07
1989Convertible super clean castrol
Buna Texas
69 Posts
Can I use this on a C 4 to clean under the car? it will not harm the springs?
Posted on: 2014/9/23 1:25
Matatk Re: super clean castrol
Don't use any cleaners on the composite spring.
Posted on: 2014/9/23 11:43
bogus Re: super clean castrol
I don't think the simple green class of cleaners will harm the springs... what will are greases, petrochemicals and the like... anything that will attack the epoxy resin.
Posted on: 2014/9/23 16:08
1989Convertible Re: super clean castrol
Buna Texas
69 Posts
so if I use this to get the heavy grease off just be sure I dont get it on the springs.
Posted on: 2014/9/23 20:19
No... these types of water based cleaners are ok. Is this a water based cleaner, or "aqueous"?
Simple Green, Purple Power... those are water based.
Water based is OK! It's petrochemical based that are bad.
Posted on: 2014/9/23 21:39
BillH Re: super clean castrol
Castrol is the same type as PP or SG. I've tries all 3 and feel Simple Green is the best, I buy it by the gallon at HomeD. But use what you want.
If you're going to use it on the aluminum A-arms, etc. , it won't work like the spray, foam chemical degreasers.
It's easier to remove some of the dirt with a nylon or brass brush ($1.99 at Harbor Freight) first then use the spray.
Posted on: 2014/9/24 0:03
if you want to clean the aluminum, us NAPA Aluminum Brightener. Matatk told me about and the stuff ROCKS!
Posted on: 2014/9/24 1:23
