292 user(s) are online (239 user(s) are browsing Forums)
Assembly Line Diagnostic Link
jonszr1 hi guys i really need your help on a hei thing i think
Lone Pine, CA
we just put a motor in a 89 firebird . started just fine . ran it for a little while turned it off to ck for leaks . then went to start it and poof nothing . turns over but no spark . wtf what do I ck for . it is a 350 .please help it is a xmas present for a buddys grandson
Posted on: 2014/12/24 23:31
Matatk Re: hi guys i really need your help on a hei thing i think
How did you verify no spark? No spark at the plug?
Posted on: 2014/12/25 2:25
I don't recall but I think the firebird might have a remote coil setup?
This is the basic troubleshooting chart for a Corvette, should be close:
Posted on: 2014/12/25 2:35
josephf31 Re: hi guys i really need your help on a hei thing i think
New Jersey
375 Posts
Check distributor rotor, wires, etc. first
Posted on: 2014/12/25 16:02
bogus Re: hi guys i really need your help on a hei thing i think
if it has an external coil, make sure the leads are clean and good.
Posted on: 2014/12/27 1:11
LD85 Re: hi guys i really need your help on a hei thing i think
Indianapolis, Indiana
784 Posts
make sure the fuel pump cycles upon turning the ignition on / but before you crank the engine.
test for spark by pulling a plug wire and putting a spark plug into the plug wire and setting the end of the plug onto steel so it is grounded
Posted on: 2014/12/27 23:17
2005/Z51
