314 user(s) are online (187 user(s) are browsing Forums)
A Collector Edition, RPO Z15.
1996 only.
LT1/A4 or LT4/ZF6....
istter1 code 36
Bakersfield Ca
2336 Posts
failed relay, poor connection at one of the relays, or poor connection at the MAF sensor itself.
Does this cover it.
Have a new MAF sensor in it
Posted on: 2014/11/18 3:14
Carol Burnett
bogus Re: code 36
yes... the older C4s are prone to wire failure... the insulation pretty much sucked.
Posted on: 2014/11/18 6:49
istter1 Re: code 36
Bakersfield Ca
2336 Posts
order both relays on amazon for $25. Will be here tomorrow. Someone mentioned that when you replace the MAF it is recommended you replace the relays at the same time.
Don't know if this is true. Will see if this is the answer tomorrow.
Posted on: 2014/11/19 3:39
Carol Burnett
istter1 Re: code 36
Bakersfield Ca
2336 Posts
Carol Burnett
istter1 Re: code 36
Bakersfield Ca
2336 Posts
Replaced both MAF sensor relays cleared codes. Drive for half hour code stays off. Go back into store start engine back up Light back 36 again
wire checking time now/ well Friday when I have time
Posted on: 2014/11/20 5:37
Carol Burnett
Matatk Re: code 36
Did you get a remanufactured MAF from the parts store?
Posted on: 2014/11/20 12:36
istter1 Re: code 36
Bakersfield Ca
2336 Posts
yes
Posted on: 2014/11/20 14:43
Carol Burnett
Matatk Re: code 36
istter1 wrote:
yes
That could be the problem as well. There are reports of guys getting 3-4 bad ones out of the box as remans.
Posted on: 2014/11/21 14:42
istter1 Re: code 36
Bakersfield Ca
2336 Posts
Matatk wrote:
istter1 wrote:
yes
that was a question on my mind
Posted on: 2014/11/22 2:40
Carol Burnett
bogus Re: code 36
Steve - donno where you are getting your MAF's from, but RockAuto.com has them for $180.00, reman'd AC Delco, plus core...
Less 5% with this code: D0499A8E6B7458
There are other options, but this looks like the best bet.
Posted on: 2014/11/22 22:47
istter1 Re: code 36
Bakersfield Ca
2336 Posts
Tested my MAF on a friends 87 vet he pulled no codes. Put his on mine still came back 36.
Messed with wires cleaned plug. No go. I start by clearing code. Will start up and run all day with no code. Shut it off re start and the code comes back up. I have already replaced the relays.
Will have a new plug here Friday. I wasn't going to pay 50 bucks from CARQUEST.
Posted on: 2014/11/24 4:05
Carol Burnett
Matatk Re: code 36
Just because you replaced the relays doesn't mean they are good. Did you save the old relays?
Posted on: 2014/11/24 4:29
Matatk Re: code 36
Matatk Re: code 36
Also, code 36 relates to the burn off circuit which happens when you start the car, that's why the light triggers on restart. I would focus on that circuit. Break out the FSM.
http://www.corvetteforum.com/forums/c ... urn-off-relay-issues.html
Posted on: 2014/11/24 4:39
istter1 Re: code 36
Bakersfield Ca
2336 Posts
Both good information. When I have time I will look into the possible solution I have never thought of.
http://www.corvetteactioncenter.com/f ... relay-sockets-issues.html
The quick fix was to remove the socket and attach a female spade connector to each wire and slide them on to the proper relay blade individually. It has now been 4 months and over 20,000 miles with no issue. The only problem now is where do I get new sockets? I don't want to get ones from a salvage yard that are well on their way to developing this same issue - See more at: http://www.corvetteactioncenter.com/f ... html#sthash.dEo6CPep.dpuf
Posted on: 2014/11/25 1:20
Carol Burnett
Schrade Re: code 36
FSM probably says to plug in a jumper wire SOMEwhere, to trigger duty cycle, THEN test for power to MAF, and ground FROM MAF, before anything else...
Posted on: 2014/11/26 19:30
bogus Re: code 36
Connectors are still available from GM. Call Chris May at Superior Chevy, 1.800.728.8267 and tell him I sent you. That was a very common connector... GM used it on many MAF sensors over many car lines.
Posted on: 2014/11/26 20:02
Matatk Re: code 36
The socket mentioned is referring to the relay socket. I have never looked for one, not sure if they are available or not.
Posted on: 2014/11/27 5:29
istter1 Re: code 36
Bakersfield Ca
2336 Posts
They are not listed correctly bit this is the one.
only $15 ordered one just incase
http://www.hawksthirdgenparts.com/mas ... elay-connector-88-89-tpi/
Posted on: 2014/12/1 3:51
Carol Burnett
Matatk Re: code 36
That's not an unreasonable price. Hope it fixes the problem.
Posted on: 2014/12/1 12:39
istter1 Re: code 36
Bakersfield Ca
2336 Posts
will know by the end of the week
Posted on: 2014/12/1 14:22
Carol Burnett
istter1 Re: code 36
Bakersfield Ca
2336 Posts
Protector detects attacking actions
can't load pictures what is this
Posted on: 2014/12/7 4:09
Carol Burnett
Matatk Re: code 36
That's your browser or a virus checker. I'm not having any issues.
Posted on: 2014/12/7 14:15
istter1 Re: code 36
Bakersfield Ca
2336 Posts
Well same message came up . No pic
replace maf sensor plug found damage wires.
Replaced burnoff relay plug damaged wires. Found a couple other relay plugs will try swapping tomorrow
same code
Posted on: 2014/12/8 1:01
Carol Burnett
bogus Re: code 36
This is the downside to these early C4's... the harness wasn't updated until 1990.
It is going to require some chasing. Also, trace back grounds.
Be willing to pull apart the black split loom stuff. There is a chance the wires have chaffed inside the loom and are ground each other out.
Posted on: 2014/12/8 18:34
istter1 Re: code 36
Bakersfield Ca
2336 Posts
Andy I found the wire problem just replacing the pigtails.
It will be fun
Posted on: 2014/12/9 14:21
Carol Burnett
istter1 Re: code 36
Bakersfield Ca
2336 Posts
no luck driving my self nuts. Will keep trying this week .
If I can't fix it will go to my friends shop during my Christmas vacation
Posted on: 2014/12/14 17:18
Carol Burnett
CentralCoaster Re: code 36
FWIW, when my MAF failed on my 85, the car would sputter trying to start but would not catch. It didn't run long enough to even throw a code. Note the 85 MAF is different than later years, so probably not worth much.
I replaced the maf with a reman autozone unit, and it was either the same or no fire at all, can't remember.
The 2nd replacement MAF though fixed it. Very frustrating to have new parts be bad, makes diagnosis a bitch.
An import I worked on with a bad MAF would only crank, nothing else.
Do you have the FSM flow chart?
Posted on: 2014/12/15 21:16
istter1 Re: code 36
Bakersfield Ca
2336 Posts
[quote]
Do you have the FSM flow chart?[/quot
Lap top down that is where flow chart is
This is the second MAF
Posted on: 2014/12/21 18:41
Carol Burnett
istter1 Re: code 36
Bakersfield Ca
2336 Posts
On step 2 the light comes on when engine running. It also clicks on and off for a second when key is in turned with out engine running. Should both lights be on with out engine running. Now that I changed plugs at burnoff relay my code reader will not connect.
jpg  fsm_code_36_page_1_76e3b7f6e4ddbd6cb695ff32f977a206034107ce.jpg (427.68 KB)
5144_549edd6703c9a.jpg 1455X2000 px
jpg  fsm_code_36_page_2_0ce1cc7977af99a926953c1736b09937713b93e9.jpg (321.33 KB)
5144_549edd8a9c6c7.jpg 1455X2000 px
Posted on: 2014/12/27 16:26
Carol Burnett
istter1 Re: code 36
Bakersfield Ca
2336 Posts
Repaired rewired from maf sensor to maf burn off relay.
Posted on: 2015/1/9 4:17
Carol Burnett
Matatk Re: code 36
Glad it's resolved!
Posted on: 2015/1/9 12:44
joeld Re: code 36
Are you saying there were bad/damaged wires in the system? I've been following this thread the last few days, seems like you put a lot of work into finding the problem! Congrats on the effort!
Posted on: 2015/1/9 19:05
bogus Re: code 36
Joel,
Yes... early C4's have a tendency to eat underhood wiring.
Heat... chemicals... vapours... take your pick, all conspire to eat insulation. It shrinks, cracks, chafes.
Once that happens, shorts are very possible.
Congrats on fixing it Steve!!! That's a killer find!!
Posted on: 2015/1/9 19:33
joeld Re: code 36
Yea Andy, I'm aware of the wire problem on most early 80's GM products. I've re-wired many over the years, some easy and some not so easy. I was just curious what the exact problem was causing the code 36.
Posted on: 2015/1/9 22:26
istter1 Re: code 36
Bakersfield Ca
2336 Posts
Now my friend at his shop has been told that on 87 c4 there is a problem in the prom that causes these vehicle to throw intermittent 36 codes and flashing the prom will fix it with the proper informatiom. Never heard of it. Tomorrow I am having him call Alvin of PMC of NC to see if they have heard of this problem. I trust them as they have done a great job on tuning my vet for all of it's up grades
jpg  1384548722016.jpg (212.55 KB)
5144_54b4a6bda3b6c.jpg 720X540 px
Posted on: 2015/1/13 5:02
Carol Burnett
