554 user(s) are online (360 user(s) are browsing Forums)
« 1 (2)
pianoguy Re: Chassis Build
Looking good! And that is a pretty fancy boom you have on your hoist ;-)
Posted on: 2015/1/14 2:07
BillH Re: Chassis Build
Boom wouldn't reach over top of the workbench, the rear & crossmember are a tad heavy.
Posted on: 2015/1/14 2:14
Just a smidge, I imagine - LOL! Nice improv!
Posted on: 2015/1/14 4:00
Half Shafts - done
First pic is of the condition of the drive shaft but the half shafts were the same.
It's impossible to get the half shafts looking like day one because the tubing is seamless steel, very smooth and shiny.
Once they rust pit, all you can do is get close.
jpg  2006-03-09 03-46-19_0012.JPG (978.11 KB)
881_54bffdd9d36e6.jpg 1600X1200 px
jpg  2015-01-21 11-56-59_0001.JPG (460.04 KB)
881_54bffdf512556.jpg 1600X1200 px
jpg  2015-01-21 11-58-18_0004.JPG (535.79 KB)
881_54bffe1146a64.jpg 1600X1200 px
Posted on: 2015/1/21 19:28
BrianCunningham Re: Chassis Build
So, how many points for pits?
Or is it a pit per point?
Posted on: 2015/1/21 21:20
Good enough for an "A" in my book.
Posted on: 2015/1/21 23:06
Got the trailing arms mostly done, parking brakes assembled.
I just have to press the bearings on to the stub axles and install BUT first I have to chuck the axles in the lathe, install the rotors and try and find one with the least amount of runout. I have 6 rear rotors to go thru. At the factory, they riveted the rotors to the axles then turned them. Once they are removed and not indexed, you're screwed.
The trailing arms sure were rusty.
jpg  2006-05-07 17-53-20_0001.JPG (878.31 KB)
881_54c3ed3c084f9.jpg 1600X1200 px
jpg  2006-05-07 17-53-48_0003.JPG (848.64 KB)
881_54c3ed4abb2a9.jpg 1600X1200 px
jpg  2006-04-13 08-41-01_0005.JPG (950.02 KB)
881_54c3ed798cb83.jpg 1600X1200 px
jpg  2015-01-24 11-44-48_0002.JPG (516.02 KB)
881_54c3edbaafd86.jpg 1600X1200 px
jpg  2015-01-24 11-45-01_0003.JPG (614.12 KB)
881_54c3edc2e170e.jpg 1600X1200 px
jpg  2015-01-24 11-45-28_0004.JPG (512.06 KB)
881_54c3edcbbd358.jpg 1600X1200 px
Posted on: 2015/1/24 19:09
I'd say that's a significant improvement. They riveted the rotors on? Sounds like it would make for a laborious brake job.
Posted on: 2015/1/24 19:29
Just for the parking brakes, unless the rotors need turned.
It takes quite a while to get the runout close, install the rotor, torque the wheel nuts, take a reading. Then do it again after rotating the rotor one or 2 studs. PIA.
Posted on: 2015/1/24 19:35
« 1 (2)
