173 user(s) are online (79 user(s) are browsing Forums)
brian gas pedal
193 Posts
i recently bought a 1988 corvette. the gas pedal in the corvette is really weird sometimes. it is really hard to push then all of a sudden it just gives out of no where and i rev it up to like 3000 rpm. ive been stuck at a stop cause i cant just ease the pedal in. i push it and it dosent move push it harder it dosent move push it even harder and then it gives and i basically floor it. anyone no why this is? sometimes it dosent do it. mainly when the car is cold.
Posted on: 2008/3/11 19:22
Woodstock Re: gas pedal
Bremen/Germany
369 Posts
Try to pull the cable by hand at the throttle body. May be the throttle body mechanics are the culprit. If it slides hard, take off the cable and spray down some silicone oil.
Posted on: 2008/3/11 19:41
91 convertible
red_johnny Re: gas pedal
Yup, sounds like a sticky cable. Mine does the opposite, I am driving along and let my foot off the petal and I keep going fast, I have to floor it to bring it back down. I gotta get some lube and get'r'done.
Posted on: 2008/3/11 20:33
brian Re: gas pedal
193 Posts
ok thanks. cause its kinda embarrassing being stuck at a light and killing it cause i didnt give it any gas and my clutch is already F*** up so flooring it isnt helping.
Posted on: 2008/3/11 21:10
RollaMo-LT4 Re: gas pedal
Trivia Winner
Rolla, Missouri
422 Posts
Brian, that is something you want to get fixed. Think of what might happen if it sticks the other way?
Posted on: 2008/3/11 21:19
brian Re: gas pedal
193 Posts
yeah there is a lot of things ive got to do to the car. so ill probably be driving my moms saturn around for a little bit cause i live downtown ATM and i cant do any work on the car till i move away from downtown on the 1st!
Posted on: 2008/3/11 21:25
