288 user(s) are online (250 user(s) are browsing Forums)
CentralCoaster Body drop possible on C4? (engine out the bottom)
Some of these photos make me curious, if it's possible to separate the unibody from the engine and suspension with a 2 post lift, leaving the engine in place. Has anyone heard of this being done? Or would it require cutting up the frame somewhere?
Posted on: 2015/6/4 1:03
bogus Re: Body drop possible on C4? (engine out the bottom)
nope... very doable..
remove the bolts at the cradle, remove the bolts at the batwing, remove the dogbones, drop the exhaust.
lift and separate.
Posted on: 2015/6/4 1:42
CentralCoaster Re: Body drop possible on C4? (engine out the bottom)
The exhaust could stay too.
Posted on: 2015/6/4 3:36
at least drop the muffler hangers...
Posted on: 2015/6/4 21:04
BrianCunningham Re: Body drop possible on C4? (engine out the bottom)
Upper shock mount part of the frame or cradle?
Looks like the upper mount is part of the cradle in the photo
Posted on: 2015/6/4 22:55
rear upper shock mounts would have to come off.
Posted on: 2015/6/4 23:47
Take another look at the photo of the "cradle"
They cut a section of the frame out.
The _actual_ engine cradle can drop out, but not with the upper suspension assembled.
Posted on: 2015/6/5 11:56
good point. Yes, upper shock mount would have to come out.
Posted on: 2015/6/5 18:09
