243 user(s) are online (207 user(s) are browsing Forums)
Matatk 1987 Corvette A/C Fan Question
Well, I was having problems with the forum and I accidentally deleted Gris' original question:
"ON A STOCK '87 SHOULD THE FAN COME ON WHEN THE AC IS TURNED ON OR SHOULD THERE BE A DELAY BEFORE THE FAN KICKS ON"
Well, the correct answer (I only gave a partial answer before) is this:
The fan is controlled by the ECM in two ways:
1) via the coolant temperature sensor when it reaches the programmed temperature;
2) via the fan control switch (located on the a/c lines) that signals the ECM to turn it on. Once the a/c is activated, the pressure will begin to build. Once it hits 233 psi, the switch will activate and send a signal to the ECM to turn the fan on in order to control the head pressure in the a/c system.
So the basic answer to the above question is: there may be a delay in the fan turning on once a/c is turned on, based on the pressure in the system.
Posted on: 2015/7/1 3:40
GRIS Re: 1987 Corvette A/C Fan Question
OKLAHOMA
7682 Posts
THANKS!
Posted on: 2015/7/1 12:58
