| Frank | Cats | ||
Will a early 90's Cat set up work on a 1984? Thanks!
Posted on: 2015/7/17 22:50
Transfer
| Matatk | Re: Cats | ||
LT1 cats (92-96) are different than L98.
1984-1985 have one style center cat, 1986-1991 are different. The main difference are the mounting flanges. That's why you'll see front pipes or catbacks listed as 86-91. |
Posted on: 2015/7/17 23:27
Transfer
| Frank | Re: Cats | ||
Thanks. You saved me from an unnecessary road trip and with the price of gas........much appreciated.
Posted on: 2015/7/18 18:27
Transfer
| CentralCoaster | Re: Cats | ||
Yeah only 84-85 are interchangeable. Now if you get an entire 86-91 system that will work too but may not pass visual. Anything else requires some fabrication.
Posted on: 2015/7/18 18:58
Transfer
Like Kevin said, anything can be made to work. I am running a 96 exhaust on my 89, but no cats and there was welding and cutting involved at an exhaust shop.
Posted on: 2015/7/19 13:55
Transfer
| bogus | Re: Cats | ||
a lot depends on the emissions laws in your state, pertaining to your car...
I wish CA would leave us older cars alone... there are not that many... |
Posted on: 2015/7/20 23:25
Transfer
Even getting a 86 catless front Y for my 85 was a trick, because it's not a 50-state legal part.
Did it to upsize to 2.5" and replace a cracked one, and have a 3" round end to adapt to test pipe. Also for CA folks you can get a universal cat that still has the correct EO numbers. All that and the smog tech didn't even look at my $90 etched numbers. ![]() |
Posted on: 2015/7/21 14:46
Transfer
Yup. I live in California so I know the pain. First time I brought my 1955 Willys CJ3B in from Arizona in 1989 they told me it had to be smogged. It has a 1962 Chevy 283 in it that is completely stock with a 2 barrel carb. It passed
and haven't had to smog it since. |
Posted on: 2015/7/24 21:22
Transfer
It's so bad here they make the out-of-state military guys smog their stuff. I was in line at the base for a parking pass and the guy ahead of me from Florida, with a DIESEL, couldn't get a pass, lol. And when I had a new truck, I had to pay a "smog abatement fee". I have to pay a fee to not get smogged. Unbelievable.
FWIW my Corvette passes the sniffer fine with no emissions on it other than a single Carsound cat. No air tubes, smog pump, nothing. Although it's burning so much oil now I think that is going to be the nail in the coffin. |
Posted on: 2015/8/4 5:27
Transfer
You can do wide open exhaust with test pipe on an 84-85 pretty easily and still be able to revert back to emissions legal if you want. You can buy the rectangular flanges and fab a test pipe, or convert to 3" round instead and use band clamps.
Technically, you can get cited for it, since driving 3k miles a year with no catalytic converter is apparently a notch above torturing and killing protected lions. Of course I only run my test pipe at the race track. Only takes 5 minutes to swap it. Hold on, some guys in black suits knocking at the door... |
Posted on: 2015/8/4 5:31
Transfer
Transfer
