284 user(s) are online (240 user(s) are browsing Forums)
pappyfreebird ok rednecks..heres me rear pic fer them that dare
1028 Posts
i been lookin at rear to much n thinkin need de tires out where posed to be ? 1/2" is to much fer spacer n studs yet ain it to small fer hub centric stud spacerthingies..i have c6 wheels 18 front 19 rears so sit in a touch..you cats know mo then me bout it..alls i do is look cool in it..tells me wud i need bruthas (yea rubbarroom shrink mo lovin etc,,)but fer de vets azz ta look good look heyhuh..thanks paps
jpg  c5rear.jpg (118.14 KB)
886_55a7041fb23cd.jpg 600X448 px
jpg  c51.jpg (128.13 KB)
886_55a70431d3ee5.jpg 600X448 px
jpg  6spd front.jpg (38.61 KB)
886_55a70469e09f5.jpg 600X448 px
Posted on: 2015/7/16 0:58
teebee Re: ok rednecks..heres me rear pic fer them that dare
12368 Posts
Stock C6 wheels, Pappy? Maybe what you need are C6 Z06, ZR1 or C6 Grand Sport wheels, the real ones not repops. They sit out wider than standard C6 wheels like you have. Then you should be able to put some real meats on the back. 325's or 345's
Posted on: 2015/7/16 2:53
pappyfreebird Re: ok rednecks..heres me rear pic fer them that dare
1028 Posts
hey teebee ..
these r factory oem c6 but offset is close up front but inch off in rear? fergit specs..19x10 wide, offset ? anyways gonna order these , ran em on ol c4 but dint have the power this has..dont pound it anyways http://www.ebay.com/itm/2-1-inch-Hubc ... 12417?fits=Model:Corvette
Posted on: 2015/7/16 14:01
bogus Re: ok rednecks..heres me rear pic fer them that dare
they look narrower... but the C6 was narrower, too.
You might want to find a rim that has the right rear C5 offset for the Z06... that should fix the problem.
I am not a fan of spacers if I can avoid it.
Posted on: 2015/7/16 16:41
1028 Posts
yea bog c5 zo6 wheels would be jus bout same..but awready have new oem c6 n new tires,,but she do sit in lil over 3/4" in (like .80") in specs ..but 3/4 adapts wont fit studs so 1" is it but r hud centric n wheel centric n conical lugs too..but 1" n dont like meants stickin out jus flush..fact dont bug me beyun in,,,but any vet nut gives me chit caus e theys in,,so since did bunch werk on some chops i aways piss me earings on stupid chit i want but wouldnt spend real money on(yea hey now make sense of them werds) but its me paps memeber.biggest werry will 1" hold power should i decide to use it now n then..gonna do a plumb string but jus straight edge inch should werk ok ,,but dont want any outside n no contact..was hopin a bunch say yea i got em etc..ol c4 was fine wid 1" ON GOTTI WHEELS sarry dint mean yell cloddy thumbs here
Posted on: 2015/7/16 17:40
CentralCoaster Re: ok rednecks..heres me rear pic fer them that dare
I don't like adapters much although they are safe.
Spacers are not, IMO. In fact most tire shops will not touch em.
You can run adapters as thin as about 5/8"
IF:
you use wheels with large depressions cast between lug holes, such as most OEM castings.
AND: you have reasonably short studs, not the ones with the starter thread base that extends out another 1/4".
AND: you use very small, low profile open lug nuts to install the adapter.
Otherwise the wheel may contact the adapter nuts or studs and not be secure. The thicker the adapters are the easier it is to clear all of that. Also I would recommend hub-centric adapters that have the false hub sticking out in the middle.
Posted on: 2015/7/16 18:02
1028 Posts
hey brutha cc ..i hear ya n thats were ir at..like c4 n gotti wheels had casting spots so long studs dint matter..dont know fer chure on these wheels but know they r oem c6..may have stock 1/4 no thread studs too..have to measure it all once theys git here..thanks bruthas .ps n yes they is hub centric n wheel centric inner chmfer fer car n lip outer fer wheel..plus conacal nuts..well thats wud i ordered,,see when gits here
Posted on: 2015/7/20 18:01
12368 Posts
Sounds like you're getting what you need there Pappy. Let's see what they are like once you get them.
Posted on: 2015/7/21 12:27
1028 Posts
well got em n purty happy wid em..did hafta take off the 1/4" unthreaded ends on studs..(fug that hurt me teeth) do have indents in wheels but chewed em off to be mo safe..she still standin tall fum beyun jacked up (no nawt talkin viagara here) anyways looks good to me no tread out etc..heres a pic..n sarry i dint realize me weenie was hangin out so ifn offends deal wid it heyhuh!!!cause such a teenie weenie aw ok ill shut up ps middle pic tryun show left adpater on left nawt
[URL=http://s451.photobucket.com/user/pappyfreebird/media/97%20c5/134beda5-1993-4aa8-8729-2c1ed9614951.jpg.html]Resized Image[/URL]
[URL=http://s451.photobucket.com/user/pappyfreebird/media/97%20c5/258e6d5b-d389-4948-a712-c54c2dca6762.jpg.html]Resized Image[/URL]
[URL=http://s451.photobucket.com/user/pappyfreebird/media/97%20c5/98364847-24bd-47f8-99f2-a87c18f81f6a.jpg.html]Resized Image[/URL]
Posted on: 2015/7/22 1:13
12368 Posts
That looks much better, Pappy.
Posted on: 2015/7/22 13:51
1028 Posts
thanks bro..i think so meself,,now kin see why i gots whinned at by a few...was werried wid the techie chit beyun .81 of inch n usein 1"ers but came out good i rekon ..better 1/4 over then 3/4 in heyhuh
Posted on: 2015/7/22 15:14
pianoguy Re: ok rednecks..heres me rear pic fer them that dare
LOL - lookin' good, Pappy!
Posted on: 2015/7/23 1:59
