166 user(s) are online (82 user(s) are browsing Forums)
LD85 New cam
Indianapolis, Indiana
784 Posts
Ok, nothing exciting, pretty average probably but this is a mild cam too,,, but I am pleased,
Temp right now is 94- Degrees in INDY
http://www.mikenorrismotorsports.com/
Gonna go CNC ported heads bigger valves, (TEA or Lingenfelter) and "maybe" Meth next spring/summer
BTR Stage 1 NA - 224/230 115 Camshaft, Peak Speed radical ported Intake, Peak Speed l Ported Throttle Body, Callaway Honker Cold Air Intake, Kooks headers 1-3/4" , Kooks Hi-Flow cats, NXT Catback, Upgraded timing chain and BTR Trunions, all else is stock
Baseline was 375 RWHP & 362 RWTQ with CAI, Headers and Catback
[URL=http://s556.photobucket.com/user/LAPCO/media/DYNO_zpsklcyzkha.jpg.html]Resized Image[/URL]
jpg  DYNO.jpg (58.90 KB)
85_55eca80791689.jpg 720X540 px
Posted on: 2015/9/6 20:55
2005/Z51
LD85 Re: New cam
784 Posts
And YES, I am keeping it stock :-)
Posted on: 2015/9/6 21:00
2005/Z51
pianoguy Re: New cam
Nice bump!!
Posted on: 2015/9/6 23:31
Matatk Re: New cam
22983 Posts
Nice numbers!
Posted on: 2015/9/7 0:11
LD85 Re: New cam
784 Posts
Apparently they are pretty much average, bu I have to say that the LS engine Technology is amazing compared to the older years,
Basically, a cam and headers LS engine nets "nearly" as much as the $7500 I spent on my L98 engine.
Posted on: 2015/9/7 0:54
2005/Z51
LD85 Re: New cam
784 Posts
My numbers are typed in backwards, should be
Baseline was 375 RWTQ & 362 RWHP with CAI, Headers and Catback
Posted on: 2015/9/7 15:22
2005/Z51
LD85 Re: New cam
784 Posts
Posted on: 2015/9/11 23:39
2005/Z51
LD85 Re: New cam
784 Posts
Posted on: 2015/9/11 23:41
2005/Z51
