| michael | 1984 front hood HELP! | ||
I just got a 1984 corvette, front engine compartment hood weighs a ton, so I ordered 2 new stabilus lift o mat gas hood struts, identical to old ones, installed them perfectly, and hood still WEIGHS A TON! Is there some other part that could be missing or broken? a spring? I just sold a Delorean, and the heavy doors had a Torsion Bar, to take most of the weight and a gas strut per side. Is there some other support mechanism? I am in DEFINITE NEED OF HELP!! Thanks anyone that has a suggestion.
Posted on: 2016/1/30 5:42
Transfer
| michael | Re: 1984 front hood HELP! | ||
Does anyone have any ideas?
Posted on: 2016/1/30 8:00
Transfer
| Matatk | Re: 1984 front hood HELP! | ||
Welcome to the site.
Unfortunately, the hood does weigh a ton. In later years, there was a large gas strut (not those mini ones) to help lift it. I can't remember if the 84 had those brackets, but I don't think so. You may be able to retrofit it, I will have to look up the info later. |
Posted on: 2016/1/30 12:02
Transfer
| CorvetteBob | Re: 1984 front hood HELP! | ||
Welcome to the site Mike. I'm sorry you're having this problem. I don't have any experience w/ 84s to be able to offer any help. I do know that the 8s have more ducting and air passages than the other C4s, so the hood will be heavier from the start.
That being said, I can't believe you're the very 1st to experience this issue, so I'm sure someone has addressed this before. If you haven't already, Try googling this issue to see what comes up. |
Posted on: 2016/1/30 14:17
Transfer
Mike -
I found this thread - http://www.corvetteforum.com/forums/c ... hood-prop-yes-i-know.html It appears it can be done, but you will need upper and lower brackets from a newer car, the piston (rod), and you will have to modify the hood with a nutsert, etc for the upper bracket. Hope that helps. |
Posted on: 2016/1/30 15:30
Transfer
| bogus | Re: 1984 front hood HELP! | ||
I was going to suggest that upgrade.
You can get most of the parts from a Corvette salvage, like www.vette2vette.com. Get new struts, tho. |
Posted on: 2016/1/31 3:14
Transfer
| j3studio | Re: 1984 front hood HELP! | ||
Quote: michael wrote: The early C4s (including your 1984 and my 1985) did not come stock with any hood struts. All they had was a single scissor support. In (I think) 1988 they went to dual struts. |
Posted on: 2016/1/31 17:30
Transfer
on my 92, there is a single big strut on the drivers side.
this is the part: http://www.mamotorworks.com/Corvette/ ... od-support-strut-609623-1 |
Posted on: 2016/1/31 18:09
Transfer
| GRIS | Re: 1984 front hood HELP! | ||
MY '87 ALL SAME-SAME, GI. GOOD EXERCISE, MUSCLE YOU UP. |
Posted on: 2016/2/1 21:59
REMEMBER THE GOOD OLD DAYS WHEN NOUNS HAD GENDER AND PEOPLE HAD SEX? ---"yellow is for folks who think a bright red Corvette is too restrained." |
Transfer
I believe he's referring to the lower assist rods: http://www.zip-corvette.com/84-96-c4/ ... pen-assist-lower-rod.html |
Posted on: 2016/2/1 23:40
Transfer
Transfer
